Hello!
I wanted to ask an opinion. I'm doing a 22W per channel amplifier with stereo controls, which will be connected to a 2-way speakers per channel. In the next picture is the circuit that connects the amplifier to the speakers. ![]() Uploaded with ImageShack.us In the following, are the speakers I can get. ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us I want to make a filter of 1st order with 6000Hz court frecuency , it gives me some results of C = 4.42uF and L = 0.21mH What do you think? Would it work well? Should I add anything else? For example, Zobel network? Thank you for your attention! |
#2 |
When you are in possess of the woofers ,put them on running for at least 5 hours ,preferably in the box . Then you can give it a listen ,also unfiltered ,and you can judge its sonic behavior - specially in the mid-trebles ,and also in the lows ,if the box chosen is the final .
The frequency response in the curve given in the brief datasheet does not tell the sonics of that woofer : it may tell you that it might reach 3 or 4 KHz ...but it is better to cut at least an octave below . Also the speaker-in-a-box response will change dramatically and some changes will lead to change component values in the crossover (if not well calculated) . Zobel networks ,that are used after the amplifier to prevent oscillations/dependence from cables ,can be used here to make the amplifier see a constant load trough the crossover , i.e. 'corrects' the impedance rise at a certain frequency ,the R determining the Q of the intervention ,associated also with the presumably high (for a coil at low frequencies )resistance of the inductor . |
#3 |
Thank you very much for your reply! I going to do a sample circuit for to see if it works. After, i will write something here.
Regards! |
#4 |
Hello again!
Excuse me for I do many questions. I'm trying make a Zobel Network now. I need the value of the inductance of the speaker, but my multimeter does not measure Henries. I can know the value of the inductance of any other way? Thank so much! Regards! |
#5 |
you (or measurement software
Le is frequency-dependent!
flesh flash flush |
| PL36 PP Amplifier 22W Full construction details | mario2005 | Tubes / Valves | 13 | 19th October 2009 05:15 PM |
| Will this work? Disassamble my old three ways & make small speakers w/seperate woofer | chris conery | Multi-Way | 0 | 18th April 2007 10:46 PM |
| Powering two Speakers from one amplifier channel. | ]|[ GorE | Multi-Way | 4 | 3rd July 2005 04:12 AM |
| 22W OTL amplifier circuit | DarkHorse | Solid State | 20 | 4th February 2005 07:49 PM |
| Scan Speak 22W/8851T00 | Antonio | Multi-Way | 0 | 3rd May 2004 04:57 PM |
| Page generated in 0.08712 seconds (75.53% PHP - 24.47% MySQL) with 10 queries |
