Old 12th December 2010, 02:08 PM   #1
Default Lambda Series TD15H
I was looking for a driver that can replace the JBL 2235H, and the AE Speakers Lambada Series TD15H has come up for prime consideration.
However, it has been suggested that there could be a mechanical resonance at 1.6 KHz due to the particular surround used. I am looking at the Reflexion Arts 234 speaker which uses an asymmetrical crossover - LPF is 12 dB @ 1000 Hz, HPF is 24 dB @ 1000 Hz.
How problematic is the 1.6 KHz resonance likely to be when the speaker is crossed over 12 dB @ 1000 Hz?
Old 12th December 2010, 02:22 PM   #2
Loren42 is offline Loren42  United States
I have 2235Hs that I replaced with TD15H in July. My crossover point is about 500 Hz. I have no issues with resonance. I can't say what it would sound like at 1 kHz.
I love JBL, but the AE TD15Hs are clearly superior drivers. I would not hesitate to do it all over again. I should sell my old 2235Hs since they are just sitting in cardboard boxes.
Old 12th December 2010, 02:48 PM   #3
What have you paired it with?
Old 12th December 2010, 04:33 PM   #4
Audax PR170M for the mid and Morel MDT38 for the high end.
Crossovers are passive at 500 Hz and 2.5 kHz.
Old 12th December 2010, 04:58 PM   #5
Thank you for your quick response. For myself, I am looking at a two way system.
Old 12th December 2010, 05:02 PM   #6
Yeah, looked at that idea long and hard a while back with no good alternatives that I liked then. The TD15H has a very high crossover point potential for a large woofer, so I was interested in seeing if I could do that.
The best way I could see doing a 15" 2-way was with a horn, but that is tricky to do and get good performance. The next choice was mating a full-range to the woofer, but that is a bit of a compromise, too.
What have you in mind to use?
Old 12th December 2010, 05:55 PM   #7
SunRa is offline SunRa  Romania
For a 1Khz crossover point, the TD15M might be a better idea. Especially if you already have some woofers around.
edit: I meant especially if you have some subwoofers around
Old 12th December 2010, 07:21 PM   #8
Brett's Avatar
I own and use the 15X and 2225/6 and agree with what the others are saying. I would either go three way in a WMT with the 15H or use the 15M if I were intent on using it like the RA234 speaker. Here the wide C-C spacing of the 15's especially if used that high could be problematic.
Old 13th December 2010, 02:27 AM   #9
LineSource's Avatar
I like the sound of the Lambda TD15S woofer and have built about twenty speakers with them. The TD15S with Qts ~ 0.37 and Fs ~ 22 Hz provides -3db at 25Hz in a 10 cu ft ported box before room gain. I think the low Qts TD15H is optimized for horn loading if you need under 40Hz with high efficiency.
If you want a high 1KHz xover plus high efficiency, the Lambda TD18H+ can be used with the Lambda TD15LO and a 1Khz controlled directivity 1" horn/waveguide. The TD15LO uses an under hung motor with the TD15M pleated edge cone.
I only design 3-way speakers and appreciate the upper midbass quality of the Lambda 15" woofers, but I seldom use bass crossovers over 160Hz. Hence, I have been watching for how new underhung NdFeB motor technology and carbon fiber loaded paper cone technology can deliver a high sound quality 18" woofer, but I have yet to find a genius solution for home audio. (90-100 gram Mms, underhung motor, 20Hz Fs, 0.37 Qts, 97 db/watt SPL, 200 watt compromise). An 18" with Qts ~0.8 also seems like the ideal choice for dipoles. With technology advancements, 18" is the new 15", and NdFeB is the new AlNiCo for bass.
Old 13th December 2010, 04:41 AM   #10
I am looking for a suitable compression driver similar to the TAD2001 and I have found several links to pursue. 15" woofers that can handle ultra lows and be crossed over above 1000 Hz are harder to find.
Thank you very much. Exactly the kind of advice I am looking for. Hope John E Janowitz will chime in for some additional clarity. He compared the TD15"H" and the JBL 2235H here and they were almost identical in the LF region.
Somehow, I am currently set on two way speakers, but this may change by the time I build my pair.
It is refreshing to see somebody who is actually looking forward to new technology. I am meeting too many people who believe that the best days of hi-fi are behind us.
TD15H Apollo's, Seas M15, HM100z0, XT25, LCY110, FR125S Bryce H. Swap Meet 10 17th January 2011 03:19 AM
Lambda TD15H Apollo's Bryce H. Swap Meet 15 29th October 2008 05:44 AM
Quality of Hammond 300 series power transformers compared to 200 series? G Tubes / Valves 8 21st September 2003 02:27 PM
Lambda TD15H woofers JohnR Swap Meet 1 23rd May 2002 09:09 PM
Page generated in 0.13027 seconds (80.08% PHP - 19.92% MySQL) with 11 queries
