#91 |
That would probably kill the low end of the tweeter.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#92 |
Second attempt at Pics for gainphile, finger trouble missed the pics.
#93 |
Nice job with the WG300s and the scanspeak. I would like to see a response curve after the tweak.
#94 |
...and polars to compare with what Rudolf did once with a front and back firing combo.
BTW, Russel that's really well done |
#95 | |
That is a very interesting approach. What are the WGs and how big are they? It would be interesting if they can hold directivity down to 1.5khz... That would be "solution to a problem" indeed Edit: .. found it, Monacor waveguide!
http://gainphile.blogspot.com |
#96 |
The purchased waveguide is 168mm. The outer edges of the guide are 89mm apart, and the gap is (was) filled to smooth the edge and increase the diameter hence cut off frequency. The purchased waveguide was close enough to my analytic prototype derived target: a 240mm OD toroid with 120mm diameter cross section, and oblate speroid transition to the dome. The doe is at the front, and the acoustic cavity at the rear appears trivial - ref below.
I used paper mache to form the torroid for the proto tests, as it has worked (for me) the next step is making the toroid for the tweeter and the mid in a more visually appealing structure. The mid also has a torroid like form, rather than a circular cross section it has an 90 x 54mm elipse, and the ellipse rotates so that it forms a moebius, for aesthetics. I am making it by using thin plywood sections set on a central frame then fill with foam, shaped and covered; like a model airplace wing mated with a surfboard. The measurements I have are here amongst hundreds of spreadsheets of single points data. Making one plot that would make sense to another person is not on my list of pleasurable activities so I will decline the offer of producing a report. My data analysis discounted higher volumes (I only have a small apartment and rather than an SL like 90 dB I settled for 87) and my hearing is second rate above 13KHz. Others might find something where I wouldnt have looked. |
#97 |
Thanks again. I'm very interested with this approach.
2 pairs of WG300 is on delivery, and I will report back
#98 |
Very nice indeed! Keep us posted, guys!
"Convictions are more dangerous enemies of truth than lies" - Friedrich Nietzsche Cardioid-like + Waveguide 2-way |
#99 |
Just trying to understand the photo of the 2904 in the waveguide, specifically what "might" be the back photo with what looks like the motor structure with a series of holes around the edge.
Is this the motor? How much output can one expect from those tiny holes compared to the front dome? Great work Cheers Dean |
#100 |
Hi guys
I read briefly through this post (reading it on a cellphone, so it is difficult to see everything), and one thing came to my mind: a lot was said about the B&G Neo3 at the beginning of the post, so has anyone thought of maybe loading both the front and the rear sides directly with two Dayton waveguides (10-inch WGs maybe)? Mounting this structure on a baffle might be tricky, and I am not sure how this loading will affect the Neo3, but then you'd have true DI-pole (as opposed to BI-pole) loading. Any thoughts? Enjoy, Deon
Reality is not digital, an on-off state, but analog. Terry Pratchett - Moving Pictures |
| Constant Directivity Horn EQ | Horizons | Multi-Way | 4 | 19th December 2008 11:41 AM |
| Constant directivity EQ | Saurav | Multi-Way | 11 | 19th May 2008 02:41 AM |
| Constant directivity horn - or waveguide? | hasselbaink | Multi-Way | 6 | 1st April 2008 01:24 PM |
| Constant Directivity Speaker Project | ding | Multi-Way | 5 | 19th December 2003 07:59 PM |
| Page generated in 0.10272 seconds (79.15% PHP - 20.85% MySQL) with 11 queries |
