Boomy TLs
Boomy TLs
Old 17th July 2003, 11:07 AM   #1
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
Default Boomy TLs
I just built a pair of M3 Transmission Lines from IPL. They are great speakers but I noticed that with certain music and on certain notes, the bass rumbles and booms unpleasantly. I have a large table in the room which I thought may be affecting the sound somehow but since moving the speakers away from it the problem remains.
The cable runs to my amp are short and there is some stuffing in the line but not a lot. My amp is an old Rotel, not a great model, could the problem be a worn out amp?? I'm currently building a gainclone to replace it. Also I thought that it could be some 'panel ringing' inside the line, though I made sure that these were well braced when I built it.
I'd appreciate some help with this problem as I'm not qualified enough to dive in and start messing with the crossover without checking first.
Old 18th July 2003, 07:43 PM   #2
DaveM is offline DaveM  United States
DaveM's Avatar
Try adding more stuffing to the line. This should dampen out some of the bass ringing at the cost of bow end extension. You need to play with the stuffing to find where it works best with your setup and room.
Dave
Old 19th July 2003, 01:15 AM   #3
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
Default No Bleating In My System
My TL's are damped with Merino long fibre wool.
I get very nice very low end rumble but no boom whatsoever.
Wool has always been the preferred damping material.
Eric.
I believe not to believe in any fixed belief system.
Old 19th July 2003, 04:55 AM   #4
asauer is offline asauer  United States
Send a message via MSN to asauer
I thought stuffing in TL's was just used to reduce the upper resonance frequencies (i.e. if the TL is tuned to 30Hz, the resonances at 120Hz, etc etc)?
Old 19th July 2003, 05:01 AM   #5
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Boomy TLs
yes, but if you don't have enuff stuffing you aren't killing those.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th July 2003, 11:44 AM   #6
Ropie's Avatar
Default Thanks
Thanks for all the advice. Will a certain type of stuffing block out just the boomyness in the small range of bass frequency that seems to be affected then? Should the stuffing go in the line, behind the woofer or both?
Boomy TLsHide this!Advertise here!
Boomy sound ruferto Everything Else 16 31st March 2009 09:42 PM
Help with loose & boomy 1st sub Marzen Subwoofers 10 28th July 2005 10:34 PM
Sounds boomy... Baki Car Audio 4 20th March 2005 06:21 PM
Boomy Sub memito Car Audio 32 8th September 2004 07:11 AM
boomy box? r_s_dhar Multi-Way 5 10th November 2003 10:19 AM
