Another converted to dipole
Old 17th July 2003, 08:48 AM   #1
Mentero is offline Mentero  Spain
Default Another converted to dipole
Hi all,
Find attached the photos of my just finished dipoles.
A lot of inspiration has come from the people in this forum, from the Thunderstone forum and of course from Linkwitz, so thank you all very much.
The full range speaker is a Supravox 215 Signat Bicone and is run full range with a PSE el34 amp.
The input for the two 15" woofers is taken at the full range terminals, with 10k series resistence and 1 uF to ground.
The 15" are cheap locally available speakers with Qts =0.4, 99dB, and 6mm Xmax. They perform very well, and barely move.
And guys, you where right, bass is excellent. And surprising.
Thanks again.
Miguel Garcia.
(Convulsive speaker builder Disease Association. Member)
Old 17th July 2003, 08:50 AM   #2
Another photo
Old 17th July 2003, 08:52 AM   #3
And the last one. Promised
Old 17th July 2003, 09:12 AM   #4
ashok is offline ashok
ashok's Avatar
Default Beautiful.
Hi Miguel,
The speakers look great. Can you describe the equalisation you have used. I am curious.
Thanks.
Ashok.
AM
Old 17th July 2003, 10:07 AM   #5
Hi Ashok,
I will wait for the drivers to break in, make my measurements and see what eq is needed. Doesn't sound like too much to my ears.
Forgot to mention that the woofers are driven by a 50+50W transistor amp.
The input of this second amp is feeded with the signal taken at the speakers terminals of the full ranger amp throught the RC filter, to compensate for the 6dB dipole rolloff.
Miguel
Old 20th July 2003, 01:43 PM   #6
Frode is offline Frode  Norway
Default Very nice!!!
What's the size of the baffle?
Frode
Old 20th July 2003, 04:53 PM   #7
Hi Frode,
Dimensions are (in centimeter) 123 X 55 X 27 (Max depth)
Miguel
Old 20th July 2003, 05:41 PM   #8
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Well Done! I like the look. Haven't you always wanted huge woofers? Did you glue up the pieces of wood or do they come in big sheets?
My speakers also have a high quality open baffle full range and less expensive pro woofers. (My woofer is in a box though.
Not surprisingly, this seems to be the formula- expensive full range run open baffle. Cheaper pro drivers for bass.
The only down side is that they end up BIG!!
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio
Old 20th July 2003, 07:56 PM   #9
chops is offline chops  United States
chops's Avatar
I like the looks of those a lot! Nice job.
Charles
Old 21st July 2003, 12:09 AM   #10
spa317 is offline spa317  Australia
Question Dipoles - efficiency??
Miguel,
Do you have any idea what the efficiency of your dipoles would be?
Or, what power is your power amp, and does it play 'effortlessly' without any clipping or stress at higher volumes?
I currently own an 8watt Audio Note Kit One SET amp, and am wondering if this would be enough for your type of speaker. I think I would need something at least 95db efficiency, preferably higher....
I am also very interested in Variac's recent Basszilla speaker he has built, also open baffle driver but woofer in seperate BR enclosure. This uses Fostex 208, but I would imagine the Supravox should be superior....How much does the Supravox cost, and where did you buy it from?
Mark (Australia)
Mark
Another converted to dipoleHide this!Advertise here!
4-pin mic converted to a 2-pin electret mic? silentblackhat Solid State 1 10th January 2008 06:50 PM
Can BR boxes be converted to TL? mikan Multi-Way 7 9th May 2006 10:58 AM
Can A CD-Rom be converted to a transport? JZatopa Parts 8 29th May 2003 10:46 PM
Copyright ©1999-2017 diyAudio
