Has there ever been a dome tweeter constructed of paper?
Old 4th December 2010, 02:39 AM   #1
River757 is offline River757  United States
River757's Avatar
Default Has there ever been a dome tweeter constructed of paper?
Paper/cellulose is still used in many low & mid frequency drivers to this day, as far as I know because of its lightness, stiffness and (some) inherent damping abilities. And paper cone tweeters, the best ones anyway, can sound quite good I think, though obviously not the equal of a modern dome especially as far as dispersion is concerned.
But does anyone know why paper has never been used in a dome configuration? I have never seen one myself. Is it something to do with physics or a manufacturing problem, or could it be a marketing issue, in other words, paper would be perceived as "cheap"?
Old 4th December 2010, 03:01 AM   #2
454Casull is offline 454Casull  Canada
How do you form paper into a dome?
Old 4th December 2010, 03:19 AM   #3
godfrey is offline godfrey  South Africa
Make it that shape. Don't start with flat paper.
Old 4th December 2010, 05:16 AM   #4
Oh. Well one of us must be a paper product engineer.
Old 4th December 2010, 05:17 AM   #5
sangram is offline sangram  India
Dome-shaped dustcaps made of paper are pretty common even today...
Old 4th December 2010, 05:51 AM   #6
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I don't necessarily agree with you on the last comment (but then i'm not a big fan of the standard conves dome). The original EPI concave dome was made of paper. It is quite a nice tweeter (not well built thou). And there are more than a few that are essentually dome tweeters with big surrounds (the Large Advent) I have seen dome mids (Philips) and dome woofers (Foster)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th December 2010, 06:44 AM   #7
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
Yep- Philips AD0210 heritage was either a hard-felt or a paper blend.
Cerwin Vega had some dome-woofer prototypes built quite a while back, but never went into production. I believe they were a non-pressed-pulp material not unlike a lot of woofer cones:
It's a 6.5" diameter dome.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 4th December 2010, 07:19 AM   #8
keyser is offline keyser  Netherlands
keyser's Avatar
A couple years ago I had a pair of Acoustic Research AR3's. They had a small paper dome tweeter, which was renowned for its sweetness. The weird thing about it was its very low efficiency, which was around 82 dB/W.
Dutch & Dutch
Old 4th December 2010, 08:11 AM   #9
frugal-phile(tm)
planet10's Avatar
Those look an aweful lot like the Foster dome woofers that come up surprisingly often.
dave
Old 4th December 2010, 09:42 AM   #10
According to Paper - Wikipedia: "In papermaking a dilute suspension of fibers in water is drained through a screen, so that a mat of randomly interwoven fibers is laid down."
I guess if you use a dome shaped screen (like a tea strainer), you get a dome shaped piece of paper.
Has there ever been a dome tweeter constructed of paper?Hide this!Advertise here!
Horn for dome tweeter Hylle Multi-Way 21 22nd October 2009 01:26 PM
hi-vi dome tweeter? bruce ferrara Multi-Way 2 22nd January 2007 03:23 PM
Dome tweeter research Audiophilenoob Multi-Way 43 13th November 2005 10:35 PM
Copyright ©1999-2017 diyAudio
