Old 2nd December 2010, 05:11 PM   #1
Default 3 way Dynaudio Argon crossover
Hi Guys, I've a old 3 way system from DYNAUDIO / DYNACAR 4 ohm. The crossover has 2 inductors, one (air core) for the mid and the second a laminated core inductor for the Woofer.
This inductor is very damaged (rust on metal and gap from metal layers) I would like to replace it but I do not know the value (H).
I tried to draw the diagram with known values.
Can someone help me?
Old 2nd December 2010, 08:42 PM   #2
David Gatti's Avatar
It looks like the mid has a 1st order highpass at 1200Hz.
I would use about 1mH for the woofer lowpass and would leave out the midrange lowpass inductor which isnt needed since the d52 as a very nice high end rolloff anyway.
Dynaudio Confidence 5 crossover (t330d+m560d) discl Multi-Way 9 1st August 2008 08:46 PM
dynaudio crossover - value of tweeter resistor? adamt Multi-Way 3 23rd January 2007 10:49 PM
Dynaudio nuance crossover caps? adamt Multi-Way 1 24th August 2006 10:36 AM
old dynaudio crossover design george a Multi-Way 2 13th August 2006 07:19 PM
Page generated in 0.05949 seconds (65.17% PHP - 34.83% MySQL) with 11 queries
