Old 1st December 2010, 10:03 AM   #1
erin is offline erin  Australia
Default Is a 21" driver too big for a 3 way speaker
Hi Guys, Just wondering if a 21" bass driver would be too big to use at home when building a 3 way cabinet for full range audio?
Does anyone have any experience building their own 3 way speakers and using a 15" to 21" driver?
Is there just too much air movement for the music to be enjoyable?
Or do you find that this size driver is perfect and what you always wanted?
Another question.
If I have the TS parameters of the driver, and I use an online cabinet calculators (such as on the Madisound website) will I actually get good results if I build a cabinet to the dimensions given, or is trial and error still required to get good sound?
I'm considering using the new eighteen sound 21" drivers. The crossover and other aspects of the design I'm OK with, but cabinets I really don't know much about.
Any suggestions or comments would be welcome.
Thanks...
Old 1st December 2010, 10:56 AM   #2
it's ok as long as your midrange is 7"-8"
21" driver in front baffle... Your wife would love it!
Old 1st December 2010, 11:00 AM   #3
Default 21"
Search for Hartley Concertmaster, they use a 24" driver.
Old 1st December 2010, 11:12 AM   #4
otto88's Avatar
Depends on at what Hz you intend to the midrange.
With 21" drivers, I'd guess the max would be about 250 Hz
Old 1st December 2010, 11:28 AM   #5
tinitus is offline tinitus  Europe
very very different beast
"ordinary" pro 21" only makes sense as a sub
and hardly as a sub for a 2way
maybe with the exception of the "Gedlee style", using big pro mid woofer 2way
Old 1st December 2010, 11:49 AM   #6
I was looking at the Eighteen sound 21LW1400.
They recommend the cut off frequency at 250Hz.
But I would guess that is when running at full power.
At home I would only be putting 50W RMS max into it so I would guess? that 400HZ crossover point would be OK?
The frequency response gets a bit rough above 250Hz but I guess that wouldnt be too bad?
I was hoping to cross over at 400Hz
Any comments?
Old 1st December 2010, 11:50 AM   #7
So you guys think that a big driver like that would not be overkill?
Old 1st December 2010, 11:55 AM   #8
I want a speaker that will move some air so that I can feel it with the bass notes, but I still want an accurate 'high fidelity' speaker with a flat(ish) frequency response.
Whats the biggest driver that i could or should get away with?
Any recommendations that anyone has had experience with?
Has anyone had experience with the cabinet calculator programs?
Are they accurate?
Old 1st December 2010, 11:59 AM   #9
check out the JBL 4350's.
I have heard these. they put out some serious bass.
Rare, weird, unusual, amazing and/or interesting... - Home Theater Forum and Systems - HomeTheaterShack.com
Old 1st December 2010, 12:00 PM   #10
that is specs for PA
not quite the same as hifi
Pyle 21" driver: Surely this cannot be. Jameson Styles Subwoofers 107 14th October 2011 03:52 AM
12" Big Alnico Guitar/MI speaker: $10 O.B.O. pjanda1 Swap Meet 1 11th January 2009 03:02 PM
Looking for good ,big,heavy 12 "Sub DriveR ZuMbAiU Subwoofers 27 18th January 2006 02:24 AM
X-over for Cabasse TC 21 speaker malisz Multi-Way 0 28th February 2003 10:19 PM
12" driver with big Xmax,low Fs, & high efficiency? WolfmanX Multi-Way 18 26th November 2002 11:10 PM
Page generated in 0.11946 seconds (82.41% PHP - 17.59% MySQL) with 11 queries
