Ive just ordered a couple of these:
CELESTION|H1-7050|HORN FLARE, ALUMINIUM, NO BELL | CPC further details: http://professional.celestion.com/pro/pdf/H1-7050.pdf question(s): Is this a horn or waveguide? Has anyone got any experience of using it, and is it any good? to me it looks a little waveguide like, but its exp flare so im hesitant to think so. thanks for any help
Im the guy that speaks in haste, and makes ill conceived theories, thinks math is a necessary evil, but i know something.Sometimes it bugs me, then i then i realise that theres 10 more just the same.So i guess Mulder was right. We are not alone. Last edited by mondogenerator; 1st December 2010 at 08:57 AM. |
#2 |
Maybe its just semantics but I always thought that all horns were waveguides. If it uses a compression driver I would definitely call it a horn (as well). If it was just a flare on a dome tweeter, increasing directivity, I would call it a waveguide.
If it is straight exponential it won't be constant directivity, will get progressively narrower at HF. David S. |
#3 |
Hi
There is exactly *no* difference between a horn and a waveguide - its all just "sales speaks". What *any* shape of horns and waveguides does, is guiding / aligning diffraction, which results in a variety of parameter shifts.
Audio and Loudspeaker Design Guidelines |
#4 |
..relatively synonymous,
All horns are waveguides, they trade/limit/compress dispersion for gain. Not all waveguides are horns, some alter dispersion through absorption. That unit is both a waveguide and a horn.. however it is *primarily* a waveguide, so it would be more "correct" to call it a waveguide. The 3.5" depth (vs. a 1" exit compression driver) is a giveaway that it's a waveguide.. the designer isn't concerned with gain but rather the specific radiation pattern of 70 by 50 down to about 3 kHz.
perspective is everything |
#5 | |
Allow me to disagree... No absorption. no dispersion due to time line tricks, plain ol' solid boundaries - its a simple horn = its a simple waveguide = its a simple diffraction alignment device ... Will have its quarter wave honk like most horns / waveguides / diffraction alignment device ... Some rubber to dampen dominating sonic pattern of pure metal is nice but not exactly a "revolution" By the way, lets state clear that "waveguide" was popularized (not invented) by Earl Geddes for mere commercial reasons > sales speak, as said .. Michael
Audio and Loudspeaker Design Guidelines Last edited by mige0; 1st December 2010 at 06:05 PM. |
#6 | |
Well then allow me to disagree with your disagreement! ![]() Waveguide is an express conjunction composed of wave and guide. If you know the definition of wave and guide then you know the definition of waveguide. Waveguide: to guide waves, or alter their pattern through physical limitation. It really doesn't matter if Earl popularized it or not.. and in fact he prefers a far more limiting definition of waveguide, which is not supported by its plain meaning.
perspective is everything Last edited by ScottG; 1st December 2010 at 06:41 PM. |
#7 |
What waveguide is not a horn?
#8 |
Certainly !
Even so I sadly must say that I fully agree to you last postMichael
Audio and Loudspeaker Design Guidelines Last edited by mige0; 1st December 2010 at 06:50 PM. |
#9 |
so called "acoustic lenses" possibly ?
They are definitely a "guidance to waves" but not exactly what one would consider as a horn (though quite often been attached to one) - hence I excluded "no dispersion due to time line tricks" ![]() Michael
Audio and Loudspeaker Design Guidelines Last edited by mige0; 1st December 2010 at 07:02 PM. |
#10 |
One that doesn't provide any acoustic gain as it guides waves.
Even a minor felt ring around a tweeter to limit the dispersion pattern and lower cabinet edge diffraction is a "waveguide".. though a very minimal one at that.
| Horn vs. Waveguide | gedlee | Multi-Way | 1653 | 25th May 2010 07:38 AM |
| Page generated in 0.11287 seconds (80.27% PHP - 19.73% MySQL) with 11 queries |
