Old 30th November 2010, 08:55 PM   #1
Kim Schultz's Avatar
Default My first OB loudspeaker, seeking advice.
I have decided to make an OB loudspeaker after having listened to this experimental setup.
This is inspired by Simon's OB with Eminence and Skytronic drivers.
My project will use an Eminence PSD2002 driver with a 90 degrees OS waveguide as tweeter. I had the driver already, and it was easy to remove the backchamber to make it dipole.
The mid will be an Eminence Beta 8a and the woofer a Fostex FW405.
The Beta 8a will cover as much as possible and hopefully run wide open without any crossover.
The tweeter will use a single cap and a lpad to bring the level down, to match the mid.
The Fostex will be in a H-baffle with a separate woofer amp and electronic crossover.
I have played around today and can see I need to have the front of the Beta 8a, about 7cm back compared to the mouth of the waveguide. This is need to time align the drivers.
Click the image to open in full size.Click the image to open in full size.
I can do this by mounting the horn flush with the baffle, and then mount the mid on an extra spacer behind the baffle, with a 90 degrees flare out to minimise reflections.
After reading some info about OB's I don't know how wide I should make the baffle.
The H-baffle will be about 45cm wide, and I thought about a 40cm wide baffle for the mid to help it go down lower, but I don't know if it is to wide.
I've also considered to make the baffle ready for a second mid like the Bastanis loudspeaker.
This would mean the tweeter will be lower than the mid, is this ok?
Should the drivers be offset on the baffle, or placed in line ?
Thx in advance, all help appreciated.
Old 30th November 2010, 09:23 PM   #2
tinitus is offline tinitus  Europe
thats a very expencive woofer
any special reason to use Eminence PSD2002 driver ?
Old 30th November 2010, 09:39 PM   #3
I have it from an old 3way studio type loudspeaker, and the previous owner had it refoamed with a smaller roll surround.
This has caused the fs and qts to go up a bit and actually making it better for OB, it sounds quite good in the simple baffle.
If the mid and tweeter section turns out good, I might get a more suitable woofer later.
Only reason for using PSD 2002 is that I had it already and it was easy to remove the backchamber.
Old 30th November 2010, 09:41 PM   #4
why ?
btw, Im still waiting for someone to try diaphragm coating on Beta-8
Old 30th November 2010, 09:49 PM   #5
I needed to move the the tweeter forward to have the impulse measurement align.
Simon did ENabl his Beta8 and some coating too I think.
Old 30th November 2010, 10:05 PM   #6
caused by crossover ?
Old 1st December 2010, 01:09 AM   #7
with double Beta-8 I would suggest to use them as 2.5way (MMT)
and upper 8" would be your listening height
With a compression driver especially Im not sure its wise with just a small series cap
and you may best try to match its rolloff with that of the midrange
not too difficult, but still a bit more tricky than just a small series cap
btw, your impulse measurement will change with a crossover
Old 1st December 2010, 07:13 PM   #8
I'll experiment with a test baffle and some different crossovers tomorrow, to see how it affects time alignment.
Old 1st December 2010, 09:37 PM   #9
Godzilla's Avatar
Good luck with your project. I see you have some neat waveguides turned over there. I am curious how the Beta 8 sounds to you without a circuit and on open baffle.
Zilla
Old 2nd December 2010, 02:26 PM   #10
I had a board 38cm x 68cm already cut that fit nearly perfect, so I used it to make a test baffle.
The mid driver is mounted behind the baffle with the edge rounded over, the waveguide is mounted flush and offset to the left, in case I want to use another mid below the other.
The measurements are taken 1m out and 30cm to the right.
The mid is run wide open and the tweeter with a 1uF series cap.
I think it looks very promising.
Sorry for the crap photos, they were taken in poor light with my phone.
Seeking Career Advice musgofasa Everything Else 9 8th January 2009 07:29 AM
Seeking Recommendations for a Basic Loudspeaker DIY Library Avid Listener Multi-Way 2 9th April 2007 10:19 PM
Help, serious newbie seeking advice!! redmagicsnake Solid State 1 21st November 2005 03:41 PM
Seeking advice on implementing opa627 I/V stage quantran Digital Source 0 30th March 2005 07:48 AM
Seeking advice for my TT project Dumbass Analogue Source 1 7th September 2003 07:31 PM
Page generated in 0.11261 seconds (82.65% PHP - 17.35% MySQL) with 11 queries
