#81 |
That directivity narrowing around 2.2khz looks strange.
Did you use the integrated passive crossover (300hz and 1250hz) ? |
#82 |
The Yorkville is Bi-amp, and we measured the Horn part (which is compression drivers + 3x midrange).
http://gainphile.blogspot.com |
#83 |
Large (90deg) DIY Unity Horn:
Red Spade Audio: Synergy prototype #2 - construction 3 ![]() ![]() Directivity sonogram, normalised ![]() Frequency plots, 0-90deg, 10deg increment, non-normalised:
#84 |
That really looks quite good. How low does it go and how does it sound in-room?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#85 |
The narrowing of the Yorkville was a surprise. It could be related to the lack of a mouth round over. There is an interesting AES paper by Keele about a certain CE horn, it basically joins an expo throat to a conical, but they found that a second flare angle was needed at the mouth to avoid beaming. This is why you see that second flare on the Synergy horn, to avoid pattern narrowing and I suspect it might be the cause of the problem.
I've built two Synergy horns so far and the bigger one shown here with the mouth flare is the smoother of the two, clearly better. Achieving pattern control so far down into the midrange does sound very different. It is a dry sound, quite unfamiliar. I believe wider dispersion that you get with just about everything except very big horns and dipoles, even in a Geddes Summa, is responsible for a sense of added body to the sound. The absence of this effect is startling. At first I wasn't convinced. A couple of things I notice about the Synergy horn. Very detailed, it's as if details buried start to emerge, low level detail. I'm not talking about the artificial sense of detail you get with some speakers, but instead you notice details otherwise missed, like a little tap of the drummer's foot. Great clarity. Extreme dynamics. Very clean and composed at all levels. There are quite a few things in common with other high sensitivity speakers, but I would say there is greater clarity and detail. That is not to say that everyone would prefer this over a two way like an Ewave or a Geddes style speaker. Within the spectrum of speakers, I would say they are in similar territory although also with clear differences. Just started a new thread on them: DIY Synergy horn
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#86 |
Dayton Audio H07E 6"x6" $8 and Celestion CDX1-1745 $90
Dayton Audio H07E 6" x 6" Elliptical Waveguide 1" Threaded ![]() Celestion CDX1-1745 Ferrite 1" Compression Driver 75W 294-2124 ![]() All measured indoor due to possible rain. 1250hz LR2 witn no eq/notches. Non-Normalised graphs: ![]() ![]() Normalised: ![]()
#87 |
Pyle Pro PH612 (Econowave) $15 and Celestion CDX1-1745 $90
Aluminium adapter is used on the compression driver to mount to screw-on waveguide ![]() Device under test: ![]() Measurement graphs. Indoor, 1250 LR2 xo, no EQ or notches Non-Normalised ![]() ![]() Normalised ![]() ![]() Very smooth directivity, rivaling B&C DE250 + the same Pyle waveguide. Three of us did listening comparison and can happily say this is as good as the more expensive B&C DE250. Very good value. Blue: Celestion CDX1-1745 Black: B&C DE250 There is nothing between them even with the same XO configuration.
http://gainphile.blogspot.com Last edited by gainphile; 18th December 2011 at 07:29 AM. |
#88 |
How do you get the PH612 in North America?
#89 |
#90 |
china "clone"
flesh flash flush |
| Waveguide | kingfisher | Multi-Way | 4 | 23rd November 2010 02:32 AM |
| Sounds like a great deal from a great guy | mikje | Chip Amps | 0 | 2nd February 2010 11:17 PM |
| FS Gainclone Great Chassis, Potted toroidal, great sound | PHilgeman | Swap Meet | 4 | 2nd May 2006 01:20 PM |
| Page generated in 0.12171 seconds (83.69% PHP - 16.31% MySQL) with 11 queries |
