Old 29th November 2010, 06:10 PM   #1
russtav is offline russtav  Russian Federation
Default 3-way.
Hello. Sorry i'm little speak English. Do you have any 3-way system with woofer CA26RFX? Please help me.
Old 29th November 2010, 06:22 PM   #2
Hi from Russia!!!
Old 29th November 2010, 08:35 PM   #3
jerome69's Avatar
See K+T
Loudspeaker Kit Coax 18
Prestige
Hope this helps
Old 29th November 2010, 10:14 PM   #4
Default Q&A First
Q1 Which driver configuration do you want to use?
3-Driver
(T)
(M)
(W)
4-Driver
(T)
(M)
(W)
(W)
5-Driver
(M)
(T)
(M)
(W)
(W)
Key
(T) Tweeter, HF
(M) Mid Range, MF
(W) Woofer, LF
Q2 Are you going to use an active crossover with (3) power amplifiers? Or, a passive crossover, with (1) power amplifier?
Also post your questions here (near page bottom left corner):
SEAS H1305-08 (CA26RFX), купить динамик НЧ SEAS H1305-08 (CA26RFX)
Old 30th November 2010, 11:47 AM   #5
Hi mans. I'm need classic 3way(t m w). I don't like active cross, because i need 3 amp+1pre-amp+3 active cross. This is realy dearly!!! But I do not deny use 4 drives for tmww. But after all two woofers will give high sensitivity and i'm don't now think good midbass with sensivity more 90(2-seas1305- woofers with compencation bafl step, we shall get 90db.... . Regards Ruslan.
Old 30th November 2010, 02:29 PM   #6
jerome69's Avatar
Hi
You have this :
CYCLOP
You could use instead CA26RFX, MCA15RCY and the 27TDFC ?
I don't know if the crossover works ine the high frequency ?
For the low frequency,it could be OK.
Regards.
Page generated in 0.07693 seconds (72.99% PHP - 27.01% MySQL) with 9 queries
