Old 28th November 2010, 02:36 PM   #1
Default 2-ways accuton bookshelf
I am ready to DIY a 2-ways bookshelf based on accuton drivers. I have ordered a pair of C158-8-085 mid-woofer but it seems there is very rare discussion of this driver for DIY.
The tweeter is considerated to use accuton C25 or C30 , Can I get some suggeston? If I want to cross at 2.5K for second-order , Does it a little over load for the C25?
If considering the Scan-Speak tweeter like ScanSpeak R2904/7000 , D2904/7100 , R3004/6620-00 , D3004-6620.....Will it get better proformance?
Asking for some suggestion for the driver selecting and cross-over point recommendation.
Thanks for everybody's help!
Old 28th November 2010, 09:43 PM   #2
The main cone break-up of the C158 is near 4.1khz; a third harmonic distortion occurs near 1.4khz; so I would try to cross the two drivers in this area. Obviously the x-max of a C30 should better suit this Fx than a C25.
IMHO, SS tweeters or Accuton ones aren't a matter of performance but a matter of taste.
crazyhub
Old 1st December 2010, 06:26 PM   #3
Thank for your information. I have contacted the local driver dealer , they said:"It is very dangerous to crossover the ceramic tweeter below 3KHz by 2nd-order filter."
Is it real? Did someone have the experiment of the ceramic tweeter? Thanks !
Old 1st December 2010, 09:39 PM   #4
Godzilla's Avatar
lol about experimenting on such an expensive tweeter.
the accuton speakers i heard at shows in NYC all sounded really good.
Old 1st December 2010, 10:01 PM   #5
A C30-6-023 has a linear excursion of +/- 1.1mm, a Fs of 570hz, is ferrofluid filled, is rated 120w power handling; Accuton recommand to cut it over 1800hz, saying nothing about the slope.
Regarding its x-max of 1.1mm, its Sd of 8.55cm² and impedance of 7.5 ohms at 1.5khz, it should theorically be able to give 109dbs / 1meter into free space (add 6dbs into half-space) at 1.5khz just before reaching its x-max. So 97dbs at 750hz (-12dbs), 85dbs at 375hz (-12dbs).
So this driver can theorically be cuted second order acoustic at 1.5khz if you project to use it half-space at max 115dbs / 1m; or still 2nd order at 2khz at max 120dbs; or still 2nd order at 2.5khz at max 124dbs. All these data are x-max related, not power compression. Nevertheless you see that the statement "It is very dangerous to crossover the ceramic tweeter below 3KHz by 2nd-order filter." isn't right in this case.
In its Humble Statement Tony Gee crosses a C30N-6-24 over at 2khz 12db/oct without any problem:
Humble Homemade Hifi
crazyhub
Old 2nd December 2010, 05:11 PM   #6
It's really expensive drivers.
I really love the sound provided by the ceramic driver. I have heard Avalon/Lumenwhite/Marten Design/Kharma/Consensus Audio Speakers and love the sound. But they are expensive and too big for me now...
So I think to begin with a small two-ways monitor is a good idea.
Old 2nd December 2010, 05:19 PM   #7
Thanks! Mr.crazyhub for providing such useful information and suggestions.
It is my first time to design a crossover circuit from the beginning. My previous speaker is Scan-Speak 9500+8545 and just used the circuit from the internet.
If I want to start with the crossover calculator which impedance should I use? From the chart of the driver to find the frequency that I want to use as crossover-point?
Old 2nd December 2010, 06:17 PM   #8
Don't even think about using a crossover calculator with such drivers,
or in fact any decent drivers. You need to do it properly as outlined
below. You needs published measurements of the drivers.
FRD Consortium tools guide
rgds, sreten.
http://sites.google.com/site/undefinition/diy
Zaph|Audio
RJB Audio Projects
Speaker Design Works
HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs.
Click below to go to
Quarter Wavelength Loudspeaker Design
The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs
Linkwitz Lab - Loudspeaker Design
Music and Design
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 2nd December 2010, 09:25 PM   #9
kevinlin I fully agree with sreten statements; accuton drivers are such accurate drivers that they obligatory need an accurate design; otherwise you will never get a fraction of what they are capable of.
crazyhub
Old 10th December 2010, 04:30 PM   #10
Thanks for the information and helps!
If I use a notch filter before the mid-woofer for dealing with the cone-breakup , Should I change the value of the capacitors/inductors(Crossover circuit) just because of the impedance it loads has been changed?(Because added the Notch filter)
The New 2-ways. Spasticteapot Multi-Way 16 19th November 2006 12:39 AM
Accuton 3-ways ? Jussi Multi-Way 135 14th July 2006 03:46 PM
Driver Selection For Bookshelf 2-ways scudinc Multi-Way 2 30th January 2006 02:28 AM
2 vs 2.5 vs 3 vs 3.5 vs 4 ways Sony Multi-Way 4 7th December 2004 03:27 PM
2-ways + sub OR 3-ways EyalR Multi-Way 12 18th January 2004 04:48 PM
Page generated in 0.11244 seconds (81.04% PHP - 18.96% MySQL) with 10 queries
