Old 28th November 2010, 02:08 AM   #1
Default Open Baffle question.
I built a pair of lampizator p17 like the photos below:
I am adding a pair of subs to the setup and was wondering if it would be
possible/sensible or what problems I would expect to hear If I placed
the subs on top of the open back box - behind the baffle effectively
almost blocking the back of the mid and tweeter drivers?
I understand this would interfere with the back wave of those drivers?
or maybe just the mid since I am using a ribbon tweeter with sealed
back as appose to conventional driver...
Is it a recipe for disaster? I am only tempted because the subs I have in
mind are a perfect fit...
Secondly.. assuming the first placement is an absolute no no...
if I placed the same subs approx 2" away from the backs of the drivers
so there was still gap all the way round, would that be a bad move too?
Excuse my vocabulary.. But I hope you get the sentiment of my question
In a nutshell I just wondered if it would completely ruin the sound.
Old 28th November 2010, 04:03 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Like this??
No you shouldn't, the pressure wave from the sub will hit the cone of the Mid setting it in motion..........
Note the example you have given, the Sub is near to the floor to better "couple" to the floor...and the distance from the subwoofer to the Mid cone is a measured precise distance. The output of the Sub will be diminished if it is "lifted" from the floor.....the backwave of the Mid "should" be unobstructed.
__________________________________________________ ____Rick........
Old 28th November 2010, 08:14 AM   #3
Thanks Richard,
That's what I needed to know. Lots to learn!
Old 28th November 2010, 10:02 AM   #4
Oh I diden't see the pic.
Yes, positioned like that but I forgot to mention that the sub has a downward firing driver (BK Monolith)
Old 28th November 2010, 10:06 AM   #5
jerome69's Avatar
It is a bad idea because you create a cavity resonance in the midrange. You will ruin the sound.
Why do you need a sub ? You already have a 15"
Read this : Greencones
I think this loudspeaker needs a serious redesign of the crossover ...
If you want more bass, you should increase the woofer inductance to 15mH.
You can use this crossover :
Uploaded with ImageShack.us
Old 28th November 2010, 10:28 AM   #6
Thanks Jerome,
I actually built mine with 18"
But since I listen to a lot of reggae I am missing a lot of the real low stuff..
it's there, down to 40hz but a lot quieter in that lower range so I probably need some EQ to help it along..
What frequency will it cross over with a 15mh inductor?
*edit* I think I worked it out... approx 85Hz?
Old 28th November 2010, 11:16 AM   #7
jerome69's Avatar
Yes
No, 300Hz The 15mH helps to go lower.
Old 28th November 2010, 01:39 PM   #8
ashok's Avatar
Might be better to use an active drive for the sub and use an electronic crossover ( passive + active) to get you the bass lift and HF rolloff respectively. It should be better than just an inductor with an iron core .
I've done this and it sounds quite good. Didn't try the (passive) inductor only as I cannot get such high values easily.
AM
Old 28th November 2010, 04:53 PM   #9
Thanks Ashok, I'll look into that if I have no luck with the passive!
Thanks Jerome, How come when I type that inductor value into this
calculator Crossover Design Chart and Inductance vs. Frequency Calculator(Low-pass)
I get a value of 84.89Hz for that inductance value (15mh)?
Sorry, Like I say lot's to learn here.
Old 28th November 2010, 05:08 PM   #10
picowallspeaker's Avatar
That chart is for 1st order (only L)
For 2nd order (L+C) , 15mH plus 68uF gives about 300Hz corner frequency
Question about Open Baffle project gvimhoof Full Range 6 3rd August 2010 08:20 PM
Open baffle question Rightbrained Multi-Way 2 28th January 2010 09:36 PM
Open-baffle design question Aengus Multi-Way 6 17th May 2006 06:37 PM
Open Baffle vs Box Speaker Question Robert McLean Full Range 23 24th May 2005 09:54 PM
Soundeasy Open Baffle Question DougL Multi-Way 2 20th April 2005 12:38 PM
Page generated in 0.10031 seconds (89.36% PHP - 10.64% MySQL) with 11 queries
