Hi
Some time ago I bought mentioned speakers , now I'm trying to change some components in crossover .I have searched the web and cannot find anything about inductor values , wonder if somebody has a crossover schematic or measured those inductors? Another option would be to buy inductance meter , but I am not sure how accurate cheap L-meters are. Here is schematic without inductance values. post-998-100006029%201198528837.gif Thanks |
#2 |
Hi
I got myself into trouble , haven't checked polarity of tweeter before and now I'm not sure if was inverted or not . How to find out? Best Regards Slav |
#3 |
Slav,
not inverted. And you got really lucky finding a pair - these little beauties really sing. ![]() Pit |
#4 |
#5 | ||
#6 | |
#7 |
Slav, I was around when the first version of the Tablette came out (late 70s, early 80s)...the original drivers are no longer available, but the newer ones are as good as the old ones. The Scandinavians build quality.
#8 | |
When polarization should be reversed and when shoulnd't , what is a deciding factor? |
#9 |
>what is a deciding factor? <
The drivers themselves, the crossover...when you have a mismatch they are at 180° phase shift at the crossover frequency and cancel each other out. Voices sound "thin", guitars have no "body"...not good. |
#10 |
Sorry but I'm still not getting .
Correct me if I'm wrong , depend on number of caps and inductors used in signal path of the speaker signal is shifted out of phase ie. 2 caps in signal path of woofer shift signal 180 degrees out of phase , lets assume there is no L or C in signal path of the tweeter - do I need to invert phase , but which speaker (woofer)? Example 2: 2 caps in woofer , 1 in tweeter - 90 degreedifference - what then? |
| add a subwoofer to my Proac super tablette | zyfb | Multi-Way | 7 | 15th November 2008 11:34 PM |
| Help with ProAc Tablette 2000 Repair | BarakaBloke | Multi-Way | 3 | 27th January 2008 12:12 PM |
| ProAc Tablette 50 Speakers | Valvomaniac | Tubes / Valves | 2 | 21st March 2007 07:39 PM |
| Proac Tablette 50 | parrymike | Multi-Way | 13 | 2nd April 2004 11:58 AM |
| photo search of the proac tablette III | mezzo | Multi-Way | 0 | 28th June 2002 12:58 AM |
| Page generated in 0.10770 seconds (81.16% PHP - 18.84% MySQL) with 11 queries |
