Old 24th November 2010, 11:16 PM   #1
Default Polyswitch fuse for speaker protection
I want to protect the 1" HF horn ( 40W/8 Ohms ) of my bass guitar cabinet with a Polyswitch resettable fuse. If I have calculated well the result for my HF is 2.23A. Do I have to match this result with the trip current of the Polyswitch? The RXEF- 110 shows a 2.2A trip current : Digi-Key - RXEF110-ND (Manufacturer - RXEF110) .Is it the right one or do I have to choose another value ?: http://dkc3.digikey.com/PDF/US2010/P2107.pdf
Many thanks,
Pascalou
Old 25th November 2010, 01:38 AM   #2
Inductor's Avatar
Yes, that's what's given by the calculator at Loudspeaker Protection Components
Input instruction (a guide line according to our experience):
For
- PA tweeters half the the rated power handling should be entered
lautsprechershop
Ref #110
Old 25th November 2010, 02:06 AM   #3
Thank you
Old 27th November 2010, 07:43 AM   #4
wolf_teeth's Avatar
Default Be advised...
I used these in a couple builds, and it actually added an ohm of resistance to the design with it engaged and not preventing the current. You may need to lessen your L-pad a smidge.
Also- I would recommend placing a 12-15 ohm resistor in parallel with the Polyswitch so that you know the driver is okay when it interrupts the circuit. It will just strongly limit its output when engaged. After the polyswitch cools, the output will return to normal.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 27th November 2010, 05:13 PM   #5
Wolf, can you - or anyone having experience too - please
say a word or two about "audibility" of polyswitches ?
Are there any effects before reaching the "trip current" ?
Is there any ageing noticeable, especially when switched
more often ?
Kind Regards
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 27th November 2010, 06:17 PM   #6
wolf_teeth's Avatar
more often ?
Kind Regards
I can't tell it's there, other than the reduced output. I have not tried it without on one of the 2 I've used them.
Don't know that either- I've never managed to trip one.
Later,
Wolf
Old 28th November 2010, 12:27 PM   #7
Thank you Wolf,
i found some information on characteristics
of PTC resetable fuses, unfortunately the
text is in german language only:
http://www.controllersandpcs.de/lehr...pass01_04x.pdf
The rise in resistance between "normal" and "tripped"
state seems to be highly frequency dependent.
Especially in the tripped state, there is a capacitive
component.
Nevertheless the elements seem to be usable quite
well for the purpose, see attached picture ...
www.dipol-audio.de
Need help to choose Polyswitch pascalou Multi-Way 0 24th November 2010 10:20 AM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
speaker protection fuse in Transcendent T8 ackcheng Tubes / Valves 1 28th March 2004 01:16 PM
Speaker protection: how to fuse? Evan Andersen Multi-Way 10 10th October 2001 05:19 PM
Page generated in 0.09516 seconds (75.15% PHP - 24.85% MySQL) with 11 queries
