Old 15th July 2003, 03:32 PM   #1
zcab911 is offline zcab911  United States
Default 2 boxes
I am getting ready to build a 2-way with two 5.5" woofers. Since the optimal box volume is 2X the box volume for a single woofer, is is better to create two isolated internal areas, one for each woofer?
Old 17th July 2003, 09:11 AM   #2
mikee12345's Avatar
aslong as the speakers are the same i think its ok to share the volume.
Old 17th July 2003, 09:38 AM   #3
Send a message via ICQ to phreeky82
i have two 5"s running in exactly doulbe the volume for a single - shared.
the problem with two separate enclosures is that you may not get them exactly the same. the problem with a shared volume is that if the placement is not the same (symetrical etc), you may get different responses. but no, i can't back this up, i've never heard a setup with a problem as such.
FS - BLH boxes t-head Swap Meet 1 23rd October 2008 04:22 AM
what do you use in your speaker boxes? newfinish Multi-Way 3 20th September 2008 11:37 PM
Can BR boxes be converted to TL? mikan Multi-Way 7 9th May 2006 10:58 AM
Why are almost all sub boxes square elambert Subwoofers 12 28th May 2005 08:49 PM
new boxes GringoAudio Multi-Way 2 18th August 2004 03:50 AM
Page generated in 0.06809 seconds (69.13% PHP - 30.87% MySQL) with 10 queries
