Old 19th November 2010, 07:41 AM   #1
Default 2-way with TPL-150H | What bass driver?
Hello forum!
I'm planing a small 2-way speaker based on the TPL-150H AMT driver from Beyma. What I'm looking for is the best 12" low-mid driver to deal with frequencies from 900 down to about 40hz.
Beyma has some designs where they use 12MWNd & 12G40. But I don't know if they are the best alternatives. You have 12B100/R with alot lower FS and a bit higher Qts which will provide deeper bass, but I'm not sure about the midrange qualities. Then you have drivers like JBL 2204h, Eminence Kappa and also others that might work, but I have no idea what to choose.
I know I'm not gonna get any deep bass from such a small two-way, but I'm looking for the best compromise between bass and midrange. I want the higghest posibel sensitivity. About 37-40hz in room response is what I'm aiming for.
Somebody who could help me out?
Old 19th November 2010, 10:38 AM   #2
The tweeter is a great choice!
I used Beyma 10G40 and 8G40, and both are great drivers, so I'm pretty sure, that the 12G40 is a great driver too.
I used 12MWnD too, but only up to 150Hz, and there it performs well, but I'm not sure, that it could compete with a 12G40.
I really like Beyma's SM112/N as a midrange driver. Maybe you want to take a look at it.
Old 20th November 2010, 06:11 AM   #3
StigErik's Avatar
Can recommend the Beyma 12G40, very nice driver. 12B100 is not a very good one IMHO.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 21st November 2010, 11:07 AM   #4
Thanks for the advice guys. Even though, I bought something else: JBL 2204h.
They seem to be a very nice compromise between low end response and mid frequency smoothness. I bought them second hand for a reasonable price.
StigErik, what is your opinion on the TPL150H vs standard TPL-150 for my application?
I'm not really gonna use the extra sensitivity, but horn version is more linear down towards and below 1kHz (which is a good thing considering my bass/mid compromise i think) and the extra directivity probably works better in my minimalistic living room?
I have the possibility to buy the version without Horn allot cheaper second hand, but I fear I will regret it if I ditch the horns....
Then plan now is: 75L box, ported to 40-45hz somewhere. Active corssover, I think I'll start with a cheap Behringer og dBx, and I'f I'm happy with the design I might buy something like DEQX later. Sounds like a plan?
Old 21st November 2010, 06:43 PM   #5
badman is offline badman  United States
Custom Title
badman's Avatar
JBL 2213/123A-3 is a pretty awesome choice- it won't maintain mid-90s sensitivity though (90). In a 2.5-3 cu ft floorstander it'd be pretty rockin- little bit high Qtc but at a lower freq so group delay should be well suppressed.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 21st November 2010, 11:26 PM   #6
Inductor's Avatar
I have the possibility to buy the version without Horn allot cheaper second hand, but I fear I will regret it if I ditch the horns.(...)
I would say the same thing, from what I see (out. curves)...
Also to consider the H dispersion of the combo W/T.
...Thanks for the advice guys. Even though, I bought something else: JBL 2204h.
I would model the enclosure with the WP simulator.
Pialign Analysis Software to help you design your enclosures.
Old 22nd November 2010, 05:06 AM   #7
mige0 is offline mige0  Austria
mige0's Avatar
Location: Austria, at a beautiful place right in the heart of the Alps.
AMT in 2-way is a challenge anyway, I'd say.
Using the horn or not will not make *that* much of a difference and you probably will end up with XO at 1kH5 rather than 900Hz, or possibly even higher (depending on SPL requirements). This horn is pretty small, after all.
Good luck, and let us know how it turned out for you.
Michael
Old 23rd November 2010, 06:02 PM   #8
Michael
Thanks for the reply, I heard some people say the same thing.
The guy I bought my 2204h's from recomended me a crossover about 1-1.2kHz, because he also felt that AMT's would have problems going below 1khz and the JBL will easily go beyond 1kHz..... but he had not tested the TPL-150H in particular. Have you?
StigErik who replied a couple of posts above you, have created som pretty awesome two-ways based on the TPL-150H, and if I'm not mistaken they have a crossover of about 900hz...
Doesn't really mater as I can experiment alot with the active XO and the JBL handles frequencies way beoynd 1khz acording to people who have used them. Since my my target sensitivity is about 95-96dB I will have to use some EQ to lower the level on the AMT, so no biggie If it drops a little towards the XO.
Thanks for the reply, I will let you know how it goes when I have started. Becaue I'm in the middle of my exams at university I won't have time the next two-three weeks.
Old 23rd November 2010, 06:16 PM   #9
Thanks for your opinion. I have decided that I will but the H version. StigErik had the same opinion.
(Thanks for the reply to my PM StigErik!)
I have BassBox pro, Unibox and winISD. Is this program any bether?
I can't test it on my normal compuser since it's runing 64bit Win 7. But if it's something special I'll use an emulator or some older computer.
Old 25th November 2010, 06:05 PM   #10
I'm thinking about using adjustable port tubes, so that I can match the port tuning to any room and to my taste.
Is that a good Idea? Do they work exactly like a fixed port or are there some drawbacks I should be aware of?
Large format simple two way TD15M w/TPL-150H or GPA604? ctrevith Multi-Way 38 27th October 2010 07:06 PM
Looking for Zapco 150H pinout input Textras Car Audio 0 8th June 2010 02:40 PM
Does anyone have Frequency AND phase response of the Beyma TPL-150H? pk Multi-Way 0 18th May 2010 04:17 PM
Magnequest EXO-99 600H/150H Plate Load Chokes cm7 Swap Meet 6 18th July 2009 01:54 AM
-Beyma TPL 150 AMT flshzug Planars & Exotics 1 23rd June 2008 11:45 PM
Page generated in 0.10515 seconds (87.66% PHP - 12.34% MySQL) with 10 queries
