Old 19th November 2010, 03:50 AM   #1
paulspencer's Avatar
Default Active system time alignment
I've been experimenting with time alignment with an active 3 way speaker and DCX. Dome tweeter + 6.5" mid in a sealed box with an angled front baffle sitting on top of a 12" Rythmik sub each side.
Using DCX auto align I get interesting delay settings! Run the routine twice and it does things slightly differently. One time it might invert polarity on a particular channel, the next time it might not, but compensate with delay differently. This is without any other changes.
Here is a typical setting:
Mid and top both delayed by 20 ms (7.8m), both with inverted polarity, then the mid has 718mm and the top 672mm delay.
Another try:
No inverted polarity but the same delay to the mid + top, 300mm to the mid and 338 to the tweeter.
Just curious what kind of settings others are finding.
As I don't fully trust the auto settings, I'm going to measure for myself when I get the time.
Without any delay settings in place, the tweeter needs polarity reversal.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 19th November 2010, 12:38 PM   #2
Paul W is offline Paul W  United States
Paul W's Avatar
Haven't used auto-align for several years, but I do remember erratic behavior if the acoustic levels were not high enough. Perhaps crank it up a bit and see if results become more consistent.
Paul
Old 19th November 2010, 12:50 PM   #3
doug20 is offline doug20  United States
Im not sure this helps and I never was succesful with my DCX auto align stuff but I used this site as a reference.
Auto-align for dummies
Old 19th November 2010, 01:07 PM   #4
Pano is offline Pano  United States
Pano's Avatar
Yes, read the link Doug provided. It will help.
I've had weird stuff happen, too, but usually it's spot on.
Old 19th November 2010, 07:50 PM   #5
JamesTRexx's Avatar
I think that just might be it. I've only had slight differences in outcome and always used the auto alignment with enough volume.
I think it's best to run auto once with just polarity, once with only delay, and once with both and then decide which one to use.
Source: FreeBSD & XMMS on VIA Eden, Terratec Aureon 5.1 / Yamaha GT-CD1 Processing: DEQ2496, 2x DCX2496 Amps: 4x EP2000, 2x EP4000
The Gate, best speakers in the world? :-)
Old 20th November 2010, 05:04 AM   #6
Radugazon's Avatar
In the manual, Behringer himself says that Auto-Align works in most of the cases...only ! This is targeting the PA world for fast settings only.
So, the best is to forget this and get familiar with a good (free...) soft, as Arta, that displays clearly impulse and step. Learning this tool is a long curve but you gonna get paid back.
feel free to mail me if you want more details, as how to get this...
Old 20th November 2010, 12:31 PM   #7
Could you provide a "dummies" version on how to use ARTA for figuring out alignment issues?
Old 20th November 2010, 06:56 PM   #8
Radugazon's Avatar
Default dummy speaking to dummies
maybe this can help ?
Old 20th November 2010, 08:16 PM   #9
Were I to do it (never did before), I would do a bit of basic trig and get the hypotenuses of the listening triangles between listening position and each driver, pick a reference, and then subtract horizontal distances from the hypotenuses to yield traveling distance difference and then just divide by c.
Tweak after that, but that should get you pretty close.
My 2 cents
Old 20th November 2010, 09:53 PM   #10
gainphile's Avatar
The easiest way to time align:
- Measure from 1m at the design axis, ideally freespace/outdoor of course
- Reverse the tweeter output/connection
- change the delay until deepest null is observed (pink noise is helpful here but impulse also ok)
- Reverse back the tweeter
http://gainphile.blogspot.com
Time alignment jmar Multi-Way 7 1st January 2010 02:51 PM
Time Alignment Dilemna the apprentice Multi-Way 4 5th November 2007 04:49 PM
time alignment? flaevor Multi-Way 7 18th August 2006 12:51 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
Page generated in 0.12040 seconds (75.29% PHP - 24.71% MySQL) with 11 queries
