Linkwitz Orions beaten by Behringer.... what!!?
Old 27th February 2013, 01:54 AM   #791
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Originally Posted by phivates View Post
What happened to Orion vs Behringer? The usual I'd say.
They inspired advanced discussions.
But really, if you look at the Orions, using back and front wave interaction to control directivity could up good in general published measurements, but has anyone looked at individual frequencies at the 1M distance and viewed the harmonic content? In listening, all sources of diffraction and reflections will make a difference, the difference can show up as some might describe as fuzziness, defocused, softened, etc. This can be good or bad depending on the amplifier and what appears upstream of the speakers. They can mask deficiencies sensitive to the ear, thus may appear to sound better; technically it has a similar effect in concept of using multiple subs in a room to obtain a certain sound balance by controlling how various source waves are combined.
The Behringer, I had listened to after this thread started. I believe that design can be further improved if it took care in amplifier design, selection of drivers, better amp/speaker interface. Personally, I would not use that kind of enclosure design because the bass will sound loose without the feeling of the lower end below 50Hz. But this guess is just based on listening to it. I think it's a pity because having gotten to this level, it does not cost too much recurring cost to make the jump in sound quality, it does take more development effort though.
Hear the real thing!
Old 27th February 2013, 02:03 AM   #792
soongsc's Avatar
Originally Posted by ScottG View Post
No it isn't.
..and you very well know that.
Lynn Olsen did not like the sound coming from the Summas at I believe an older RMAF.
He was kind enough however to suggest that the reason for that conclusion was due to the mass-market amplifier you were using with the Summas.
That's a "poor review" under "show conditions" by any standard. It also precisely parallels Ohmolts comment:
"You cannot dismiss a speaker based simply on an experience from a show. Gedlee speakers have also received poor reviews from demos like that. But the fact is that they are both great speakers."
Which wasn't a derogatory statement AT ALL.
In fact, if anything it was complementary - but you seem to view even the slightest criticism as an attack, so it probably never dawned on you that it was complementary.
I have VERY seldom found any speaker to sound good at ANY show. I even wonder why the companies care to show up if they do not want to take the time to get the best possible sound during the show.
Old 27th February 2013, 03:28 AM   #793
Pano is offline Pano  United States
Pano's Avatar
Soongsc, I have a few time and been quite delighted. It's a minority, but it exists. Oddly, many speaker designers do not know ow to set up speakers at a show. They really don't.
Originally Posted by gedlee View Post
The fact is that no Abbey has ever been shown at a show (I don't do shows)
You don't? You've complained on this very forum about the lack of interest you've gotten at shows. Weren't you at RMAF and even LSAF a few years back?
Its the thermal dynamics - small speakers cannot handle the thermal aspects like one very large one can. Its not magic, its quite logical.
Quite agree and that's what I heard (and smelled) with the CBT. You can hear the speaker cone when they get loud, you can smell the resistors when they get hot. But considering the size of the speaker, it does very well. For most domestic use I think it will play loud enough.
Take the Speaker Voltage Test!
Old 27th February 2013, 05:05 AM   #794
Elias is offline Elias  Finland
Elias's Avatar
Still no love for IMP around here, I can see
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 27th February 2013, 05:09 AM   #795
ScottG is offline ScottG  United States
It's tough without detailed info on the design.
IF we had that then I suspect that a few people would "knock-out" a copy and try it out.
perspective is everything
Old 27th February 2013, 05:37 AM   #796
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally Posted by thomasjefferson View Post
I noticed when reading reports from RMAF that many people raved about the NOLA speaker, which has four widely spaced tweeters and four small widely spaced midrange drivers in an open baffle. Maybe this has similar traits to the IMP, or Bose 901, etc. Turns out to be a crowd pleaser.
Yeah the NOLA is a real head scratcher.
I've heard it a few times and I'm always mystified by why/how it sounds so good.
Clearly the dipole radiation pattern has something to do with, but the numerous midranges and tweeters are a mystery. I asked the designer about it and he didn't seem interested in giving away any info.
Old 27th February 2013, 05:43 AM   #797
Melo theory is offline Melo theory  United States
Melo theory's Avatar
Weird isn't it? A speaker that beat the Orion several years ago....
And there is no info to be found.
I LIKE YOU
Old 27th February 2013, 05:55 AM   #798
I agree, we've probably spent too much time fixated on the speaker that came in third!
Here's some info on Gary Eickmeier from the internet:
https://secure.aes.org/forum/pubs/conventions/?ID=52
"The authors say that they will be doing future studies of radiation patterns and speaker positioning and would welcome input from the membership. Sigfried Linkwitz has challenged the membership to find the ultimate radiation pattern, speaker positioning, and room characteristics for stereophonic reproduction. I wrote a paper in October of 1989 that did not get published that answers all of these questions, and I would like to have my suggestions included in any future studies, but there is no directory of members' Email addresses so I can talk to anyone.
My paper was "An Image Model Theory for Stereophonic Sound", preprint 2869,
AES E-Library An Image Model Theory for Stereophonic Sound
and it gives the basis for the selection of "The Big Three" (radiation pattern, speaker positioning, and room acoustics) and my resultant choice for all three. The importance and urgency to communicate my suggestions is that others may not have considered my Big Three in any testing, and the problem is that if you get any one of them wrong, the whole image collapses and you would not know how close you are to the answer.
The paper proposes a different way of looking at stereophonic sound (the realistic reproduction of auditory perspective) that has been hinted at in previous work but never completely solved. I wish to correspond with whoever might be interested. I consider this a most important topic, and one of the last questions to be answered in audio engineering.
Gary Eickmeier"
Old 27th February 2013, 06:13 AM   #799
Here is Eickmeier's paper, "An Image Model Theory for Stereophonic Sound"
https://docs.google.com/file/d/0B0T6...DYw/edit?hl=en
Old 27th February 2013, 06:44 AM   #800
Thats some small print. I can't read it.
I see the drawings but I can't make out what the descriptions are.
I LIKE YOU
Linkwitz Orions beaten by Behringer.... what!!?Hide this!Advertise here!
WTB Linkwitz Orions jrling Swap Meet 0 13th March 2010 06:26 PM
Finally finished my orions srfranci Multi-Way 5 24th July 2009 12:29 PM
My week with the Orions, or 'why do we bother' cuibono Multi-Way 56 26th October 2008 01:51 AM
Can the Dynaudio C1 be beaten by a DIY design obiwan Multi-Way 16 22nd July 2007 11:19 AM
How hard to clone the Orions? Chaucer Multi-Way 46 8th July 2005 03:01 PM
Copyright ©1999-2017 diyAudio
