Linkwitz Orions beaten by Behringer.... what!!? Linkwitz Orions beaten by Behringer.... what!!? - Page 200 - diyAudio
Old 19th March 2013, 01:35 AM   #1991
Soundtrackmixer is offline Soundtrackmixer  United States
Originally Posted by ScottG View Post
..about 20 minutes for me.
I didn't have a problem with the content of your post, but the format (with the spliced-up quotes) read more like a p!ssing match.
Next time consider just one quote (or maybe two).
Sometimes a p!ssing contest can just be an honest disagreement of thoughts and facts. I guess it depends on your perspective.
Soundtrackmixer - M.P.S.E/AES/SMPTE member
Old 19th March 2013, 04:35 AM   #1992
dewardh is offline dewardh  United States
Originally Posted by Soundtrackmixer View Post
Just like Hollywood is 3D' ing everything, you can bet they will use Atmos for a "A" list vintage classic title.
Oh great . . . "colorized" sound for the "colorized" movies.
Old 19th March 2013, 07:30 AM   #1993
markus76 is offline markus76  Germany
Banned
Originally Posted by j.michael droke View Post
Hi there: Found a picture of SRS's version of"OBA". Google-up Orange County Register. They posted a photo of SRS dmonistration system, sems to use 6 computer sized front speakers and 4 pole mounted boxes about .75cf mid room. Great WAF! Looks like this is another market driven hitec gambit. ...regards, Michael
Object based audio is independent of the renderer. Could be a mono speaker in front of you.
Old 19th March 2013, 07:45 AM   #1994
Banned
Not true. The system can be used with any soundtrack from any period. Just like Hollywood is 3D' ing everything, you can bet they will use Atmos for a "A" list vintage classic title.
They will probably do that but honestly it does a disservice to object based audio if they don't do a complete remix or use sounds that can't be handled as objects.
The inclusion of "beds" in Atmos is also a very bad idea in my opinion. It's there for practical reasons but as much as it helps maintaining old workflows, it hinders or slows down adoption of new workflows that would make use of the new possibilities, e.g. accurate reverberation simulation with reflections coming from multiple angles.
Old 19th March 2013, 08:31 AM   #1995
lolo is offline lolo  France
lolo's Avatar
Yep.. how funny it is to see how poor an artistic content can bear these new technologies. It's a sad shift from a medium amongst others to... a mean in itself!
As a result, I am not going to the theatre anymore, maybe five times a year total. I used to spend my days in them.
Old 19th March 2013, 09:42 AM   #1996
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by markus76 View Post
Ambiophonics overcomes gross HRTF errors?? Instead of delivering everything through 30 it delivers everything through 0. Is that less erroneous?
That is not actually right, the recommended speaker angle is not 0deg but something between 5-15deg.
And yes it is less erroneous. If you take propability distribution of the intended image span angle of stereo recordings, it is more likely the image is within, say, +-10deg than +-30deg. Then it can be said HRTF errors are statistically reduced.
Are you sure stereo itself doesn't sound artificial because of low accuracy of the wave field and inability to deliver pivoting cues? Did you try listening under anechoic conditions, e.g. outside?
Stereo triangle ITD errors are related to erroneous wavefield. Head movements make them more apparent, but they exist also with fixed head. The room is a dramatic ITD error contributor as well.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 19th March 2013, 10:07 AM   #1997
Elias's Avatar
Originally Posted by Rudolf View Post
And don't tell me that mono is better.
Mono is better than stereo triangle in some aspects The wavefront of a single mono speaker is more natural than the wavefront of a stereo triangle, because the velocity vector of propagating wave is unity as in a real sound source.
Old 19th March 2013, 11:11 AM   #1998
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Originally Posted by Elias View Post
Mono is better than stereo triangle in some aspects The wavefront of a single mono speaker is more natural than the wavefront of a stereo triangle ...
I understand that. But "better than stereo triangle in some aspects" doesn't make it better on the whole. I'd rather listen to something not perfect while waiting for the next audio revolution.
www.dipolplus.de
Old 19th March 2013, 11:21 AM   #1999
Banned
Don't know about the statistical distribution of phantom sources but is less HRTF deviation perceptually less severe?
Given the fact that a) virtually no binaural recordings exist and b) the majority of all recordings work with interchannel level differences that are greater than interaural level differences of natural sounds, is it sensible to look at stereo as a binaural reproduction technique at all?
Old 19th March 2013, 01:26 PM   #2000
Barleywater is offline Barleywater  United States
Oh come on Elias, velocity vector of propagating wavefront is speed of sound. Sound field formation is wave superposition.
No standards in stereo: Recordings are mixed/monitored with approximate equilateral triangle, and then listened to with remote headphones using a partition, and all sounds better? Just a variation on a theme of how brain responds to two sounds correlated in time and disjointed in space. Really, for everyday listening?
5.x 7.x 9.x sound: Each speaker pair forms phantom image for correlated signals. If one poor phantom image doesn't work well, a bunch of them will?
Imaging performance works best with point source. The degree to which radiating wavefront of speaker projects back to single point for all frequencies, the better the speaker's imaging performance will be. Theory of omnidirectional speaker obviously seeks this goal. Dipole and cardioid in theory also project to point. In theory, some waveguides do, many don't.
Speaker transducers with excited break up modes project back to a distribution of sources that sum to point that is state driven, and thus bounces about in space.
Ripple in frequency response, even in anechoic chamber, with small shifts in microphone demonstrate deviation from point source behavior, and is good starting place for assessing point source character of drivers/speakers.
Clearly the IMP presented more point like source than Behringer or Orion. Test wasn't about timbrel accuracy. Test was about detail of phantom image.
IMP is crappy box, but shading of drivers, and identical drivers gives it better point source characteristics.
Baffle width of Orion, midrange size, crossover point to tweeter, and spacing to tweeter limit phantom image detail. At distances where angular aperture becomes narrow, direct/reflected ratio is poor and room sound buries low level spacial detail in recording.
Behringer has narrower baffle, but crappy box.
Surprising results? Not when the physics are understood.
Linkwitz Orions beaten by Behringer.... what!!?Hide this!Advertise here!
WTB Linkwitz Orions jrling Swap Meet 0 13th March 2010 05:26 PM
Finally finished my orions srfranci Multi-Way 5 24th July 2009 11:29 AM
My week with the Orions, or 'why do we bother' cuibono Multi-Way 56 26th October 2008 12:51 AM
Can the Dynaudio C1 be beaten by a DIY design obiwan Multi-Way 16 22nd July 2007 10:19 AM
How hard to clone the Orions? Chaucer Multi-Way 46 8th July 2005 02:01 PM
Copyright ©1999-2017 diyAudio
