Here we go!
Now it needs the right innerdiameter
Holy cow, you're not messing around.
The first ventport is done, it looks very cool! It'll work just perfect in Piccolo Mostro III. Here's a question for ya, you know what Piccolo Mostro means?
How do u mean?What about an 'all cardboard' version ??
Well, it does not have to cost much (Read a lot) to sound good, as long as you do it right. For an example, I think Marten Design sounds terrible and they cost very much!! And lot of Canton speakers... to say a few brandsI mean : it doesn't have to stand an huge pressure ,total force is given by the two 4" paper cones . I just think it is oversized in terms of Q(quality)/P
(pounds ,the weight ) .
That's all !!
I have heard many brands costing 1/8 sounding better
The ends are at 30 degree angle, pointing downwards Will show a photo of my first complete port tonightI specified the weight ,referring to 'pound' . Are you going to make flared shape ends in the duct ? Does it fire backwards or downwards ?
One done, one to go
That's not a proper 'flare' . Or it is ? It may be ...
I had an idea not yet copyrighted
You could use a steel plate with an L shape , the vertical part supports the drivers ,the horizontal one has the duct in it ,and the spikes on it . Clever ,ha ?
the enclosure is 1 cm plexy ,(with transparent aerogel foam ,very chic!),binding posts on the rear .
Just for an idea ...if no sound absorber would to be used (either if white dacron may be...sexy !!)
These speakerterminals is mine in a couple of weeks
Not at all!This is like building a house this way:
1. Selecting and buying all the wall paint.
2. Picking out the colour of the window curtains.
3. Doing at that other boring stuff (ie. foundation, floor, walls, roof, etc)
I have all the walls, baffle, drivers, boxvolume ready.
I have it here in my home
I have not left out anything, of course is the sound prio nr 1
Little Monster! (OK, so I had to use Googe Translate.)
This is an interesting thread so far. I'm keen to see the completed project!
Yeah!Little Monster! (OK, so I had to use Googe Translate.)
My latest idea;
I am looking into getting my "rings" done in wood
- New Project
