I was finally able to get Arta working and test the vintage Oxford/Acoustic Wagner 15" drivers I picked up.
The results weren't what I expected and I guess I need some help figuring out what it all means. ie.. Are they worth any more time and if so, in what sort of enclosure/baffle? ![]() Parameter Value Dim Fs -- 77.3 Hz Re -- 7.2 ohms[dc] Le -- 504.33 uH L2 -- 1046.4 uH R2 -- 17.56 ohms Qt -- 2.6 - Qes -- 2.99 - Qms -- 20.27 - Mms -- 39.26 grams Rms -- 0.940817 kg/s Cms -- 0.000108 m/N Vas -- 6.93 liters Sd -- 213.82 cm^2 Bl -- 6.780901 Tm ETA -- 0.1 % Lp(2.83V/1m) -- 82.7 dB
I made smoke! |
#2 |
at first -must be about 8xx cm^2
flesh flash flush Last edited by Flaesh; 13th November 2010 at 12:47 AM. |
#3 |
Ha! How'd I miss that?
That's weird... Arta asked for the membrane Diameter in cm... I entered 16.5. So I don't know how that happened.
I made smoke! Last edited by Kilroy; 13th November 2010 at 12:58 AM. |
#4 |
Freakin' math.
![]() ![]() The RIGHT T/S parameters! Parameter Value Dim Fs 77.58 Hz Re 7.2 ohms[dc] Le 518.26 uH L2 1110.59 uH R2 19.29 ohms Qt 2.67 - Qes 3.03 - Qms 22.02 - Mms 25.63 grams Rms 0.56732 kg/s Cms 0.000164 m/N Vas 149.17 liters Sd 804.25 cm^2 Bl 5.444417 Tm ETA 2.21 % Lp(2.83V/1m) 96 dB But now the Vas looks funny?!
I made smoke! Last edited by Kilroy; 13th November 2010 at 01:50 AM. |
#6 |
I don't know... This is the lightest driver over all that I've had in my hands over 10"... Maybe even over 8"... It's just not that substantial.
The cone is thin paper.... But that does seem a little on the light side... But if I messed up on the data entry this time, I can't see where. Upon further examination They have a very light, flexible cone with a very stiff surround... I've honestly never seen anything quite like them.
I made smoke! Last edited by Kilroy; 13th November 2010 at 02:21 AM. |
#7 |
Speakerholic
15" with Fs of 78Hz and a Q of 2? Sounds like an old instrument speaker.
#8 |
Speakerholic
#9 | |
I made smoke! |
#10 | |
They were supposed to have come out of an in wall house installation, but I have my doubts.
I made smoke! |
| FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 | nl | Swap Meet | 2 | 10th June 2009 10:15 PM |
| Two 15" late 1950s Vintage Magnavox Woofers with Alnico magnets for sale! | WBS | Swap Meet | 0 | 23rd February 2009 11:22 PM |
| 2 Jensen P15-RJ vintage 15" speakers | GordonW | Swap Meet | 2 | 2nd August 2007 02:17 PM |
| Vintage Audax A150-X 15" coaxes | whiteSE | Swap Meet | 2 | 1st January 2007 08:02 PM |
| how do i find thiel small parameters for the radio shack 40-1035 15" woofer | zuki | Multi-Way | 7 | 18th February 2004 12:55 PM |
