What fullrange for OB? - Page 6 - diyAudio
Old 15th November 2010, 07:58 PM   #51
el`Ol is offline el`Ol  Germany
You would have to do it on your own. The advantage of the Hawthorne would be that crossover is included.
And still cheaper with shipping. Shipping outside US is really expensive as I remember from an other forum, but their drivers are really cheap.
Old 16th November 2010, 11:07 AM   #52
oLjud is offline oLjud  Sweden
I'm thinking about order the Fostex FE166EN later today. It good T/S params for its purpose and has a low price.
Since its my first OB-project and I'll actually never heard an OB-speaker I thought it might good to keep to total cost low, and if I like the sound I can later try different fullrange drivers.
And also the FE166EN looks like it doesn't need so much crossover eq...
I'll post some photos when the speakers are done (or check my webpage regularly )
Current DIY-project: FAST-speaker with scanspeak and faitalpro / Anaview amps with minidsp / 2way synergy horn
Old 16th November 2010, 11:15 AM   #53
The Hawthrone driver looks really great! But I calculated the cost quick and it's to expensive for me, I'll go low cost instead. I just don't have the budget for it at the moment... must prioritize some other stuff at the moment.
But if I like the OB sound I definitely going to check it out later!!
I really appreciate all the comments and help!!
Old 16th November 2010, 11:42 AM   #54
MJK is offline MJK  United States
Keep the acoustic crossover low around 200 Hz. This means that you need to design the 12 dB/octave electrical crossover network taking into account the dipole peak and the H frame first resonance. I think your plan is good and look forward to your future reports and seeing pictures.
Good luck,
Martin
Old 16th November 2010, 03:24 PM   #55
Good luck,
Martin
I'll thinking about going something like you did with the fe103 and alpha15, should work pretty well in this setup too.
Hopefully I get some time this weekend to start building the speaker, photos will be shared here and I'm hoping to get some inputs on them.
Old 17th November 2010, 04:13 PM   #56
Just ordered Fostex FE166EN, hopefully the shipping doesn't take so long. My Alpha 15 will probably arrive home this Wednesday...
To bad I study for a math test too, all my mindpower will most likely go to the speakers :P
OB fullrange plus tapped horn? Racket Scientist Full Range 3 24th September 2010 05:27 AM
8" and smaller fullrange vs 12" and up fullrange in OB c3conv Full Range 11 24th August 2010 06:59 AM
OB fullrange driver to use with JBL LE14A vaughn Full Range 3 9th June 2009 02:20 AM
Cheap Philips fullrange on OB Calamaro Full Range 10 16th October 2008 04:50 PM
fullrange for OB? nicoch58 Full Range 1 11th February 2008 08:36 PM
Copyright ©1999-2017 diyAudio
