Old 30th December 2010, 10:34 AM   #51
kipman725's Avatar
Send a message via MSN to kipman725
MDF - it's cheap and dense and well damped. The concerns about it pushing the resonance of the cabinet down are valid considering that there is more energy at lower frequencies but the cost advantage is very hard to ignore unless your spend on driver is >200GBP. However due to the much lower cost a more elaborate cabinet could be constructed that is much more damped than the same cost ply cabinet at the expense of size/weight (sand filled enclosures etc).
Old 2nd March 2011, 07:19 PM   #52
zman01 is offline zman01  Bangladesh
Default Ok for plywod layers to be uneven?
Just googled and downloaded some images of baltic birch ply cross sections.
If you look closely at the pics, you will notice:
1. Colors of the layers are different - some of the layers look light colored and hard, while others look slightly darker colored and a softer
2. Thickness of layers slighly uneven - and thickness of each individual layer is not uniform over the legth of the board(sometimes it looks slightly wavy)
I have never bothered to take such a close look at ply boards before, but is this normal?
Old 2nd March 2011, 07:31 PM   #53
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
the plywood layers alternate grain direction. when you cut across it you are seeing end grain on one layer and long grain on alternate layers. The core is glued together however it is and then the sheet is sanded to an even thickness. so yes the waves in the layers are normal. Baltic birch ply wood or apple ply are usually better then most in this respect.
Hi-end piano real wood cabinet weimanken Swap Meet 2 11th September 2009 10:20 AM
New cabinet under construction. Andy G Multi-Way 42 23rd June 2008 06:43 AM
lightweight wood for cabinet? NED 209 Multi-Way 8 13th April 2008 06:57 AM
cabinet construction tenderland Full Range 16 9th January 2005 02:52 AM
Pine wood cabinet palesha Multi-Way 3 11th February 2002 07:06 PM
Copyright ©1999-2013 diyAudio
