Old 14th July 2003, 12:27 PM   #1
octopus is offline octopus  England
octopus's Avatar
Question Are these Caps or Resistors?
I'm working on a commercial speaker but having trouble with the components. The image below shows a 2-way crossover, but I can't figure out what the yellow components are. The little one has 395J and the other has 106J on there bodies. There is already a capacitor there so are these yellow things resistors?
I have a schematic of the circuit (that I made) if that helps.
Old 14th July 2003, 08:27 PM   #2
Send a message via ICQ to Brett D. Send a message via AIM to Brett D. Send a message via Yahoo to Brett D.
The yellow items are non polar capacitors, the capactitor sticking
up off the board is a polar capacitor, the white rectangle is a
ceramic resistor and the two round pieces of ferrite with wire
wound on them are inductors.
Old 14th July 2003, 08:40 PM   #3
I agree with Brett. The yellow thing with 395J written on it is a foil capacitor with a value of 39*10^5pF=3.9uF +/- 5%. The one with 106J written on it is a foil capacitor with a value of 10*10^6pF=10uF +/- 5%. (J is a tolerance code for +/- 5%.) The white thing with 2R2 J on it is a 2.2 ohm +/- 5% wirewound power resistor in a ceramic package.
Old 14th July 2003, 09:07 PM   #4
octopus's Avatar
Thanks very much guys.
Old 15th July 2003, 09:12 AM   #5
Do you have a complete list of the tolerance codes?
Old 15th July 2003, 11:41 AM   #6
LaMa,
I used to have a list, but I don't know if I still have it somewhere. A few that I know by heart are:
F +/- 1%
G +/- 2%
H +/- 2.5%
J +/- 5%
K +/- 10%
M +/- 20%
P +100/-0 %
Z +80/-20 % (I'm not completely sure about this one).
Old 16th July 2003, 03:35 PM   #7
octopus's Avatar
OKay, here comes the reason why I needed to know this...
I wanted to add a zobel network (experimentally) to the crossover and make the circuit path shorter. The result?
A tiny crossover for the tweeter - unaltered except the inductor goes after the two caps.
The woofer and tweeter crossover in the enclosure - the blue capacitor and white resistor are the zobel section.
I've written up the entire proceedure from start to beginning on another forum - http://forum.hifichoice.co.uk/viewtopic.php?t=6055
The result is very positive - I hear more that I did before and it sounds so much more natural.
I also upgraded the cable wire - thick for bass and thin for treble which is much better
Thanks again
Old 17th July 2003, 01:59 AM   #8
What OEM speaker are those XO's out of?
I was going to spend some money and upgrade my XO's (shown
below) with AudioCap Theta's, Mills Resistors and Jantzen Foil
Inductors but ultimately I just decided to leave them alone and
build new speakers. I did rewire everything with 12Awg though.
Old 17th July 2003, 07:08 AM   #9
frugal-phile(tm)
planet10's Avatar
Originally posted by Brett D.
the capactitor sticking up off the board is a polar capacitor
Much more likely is is a bi-polar electrolytic, likely in the bass circuit.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th July 2003, 12:24 PM   #10
octopus's Avatar
"What OEM speaker are those XO's out of?"
Eltax Linear Response 6.5 circa 1998, discontinued now.
"Much more likely is is a bi-polar electrolytic, likely in the bass circuit."
I think it is bi-polar, it has "BP" labelled on the side. The electrolytic capacitor I used for the zobel is also BP.
For the second speaker I left out the black capacitor (10microfarad), will this effect the sound much? I haven't actually done some real listening yet.
Caps coils and resistors guru_jeff Multi-Way 2 20th June 2010 05:39 PM
FS: Used Caps, Coils, and Resistors Rybaudio Swap Meet 4 13th July 2007 11:40 PM
Various FS:esp boards/caps/resistors UK RobWells Swap Meet 17 23rd April 2005 09:28 AM
Resistors and caps in active XO Kjetil Digital Source 0 5th April 2004 04:26 PM
Page generated in 0.14330 seconds (67.98% PHP - 32.02% MySQL) with 11 queries
