Old 8th November 2010, 02:30 AM   #1
Steve Eddy's Avatar
Default 2 inch, 500 Hz rectangular horns?
Are there any outstanding, off-the-shelf, baffle mount, 2 inch, 500 Hz rectangular horns out there?
se
Q
Keeping it simple since 1998
Old 8th November 2010, 06:30 AM   #2
pos is offline pos  Europe
pos's Avatar
500Hz as the horn cutoff frequency, or as your actual crossover frequency?
And what dispersion pattern do you look for?
Old 8th November 2010, 06:40 AM   #3
Steve Eddy's Avatar
Crossover frequency.
60 or 90 x 40.
se
Q
Old 8th November 2010, 06:58 AM   #4
pos's Avatar
It is going to be big! (and even bigger in 60° version, if you want horizontal directivity control down to 500Hz)
JBL current offering is meant for 1.5" drivers.
If you are not afraid but the size (and depth!) the 2360/2365 (especially the B versions) are good candidates.
If constant directivity is not mandatory the TH4001 could also be a candidate.
Old 8th November 2010, 07:16 AM   #5
DorinD is offline DorinD  Romania
DorinD's Avatar
I recommend you Selenium HM4750-SLF horn and D405 driver crossed at 500Hz and 5kHz, very satisfied with them.
Old 12th November 2010, 12:19 PM   #6
Default Horn DIY
se
Horn DIY
If you relax your mounting requirements and build it yourself, you will get superior results for the money and time spent. See what is possible at the following website [1]
WHG
[1] Yuichi’s Audio Lab
Yuichi's Audio Lab.
Do rectangular front horns have to be horizontal Bill poster Full Range 15 13th October 2010 03:46 AM
80 hz 15' conical midbass horns winslow Swap Meet 1 7th August 2010 12:16 AM
C-C spacing between woofer and tweeter with 500 hz XO Defo Multi-Way 2 3rd July 2010 02:31 PM
Best bass horn 50 – 500 Hz rick57 Multi-Way 37 6th March 2005 09:38 PM
D.I.Y. 50 Hz bi-radial front horns rcavictim Multi-Way 15 17th August 2004 09:45 PM
Page generated in 0.86126 seconds (8.87% PHP - 91.13% MySQL) with 10 queries
