Im a bit confused with the response
Bearing in mind I have no test equipment, this is purely though listening Some tracks sound fantastic, suprisingly low considering its a 3" driver, you kind of look at them in suprise that they are generating it when you are used to having a 10" sub boost your bass! Yet others seem to have no bass whatsoever Would this indicate that I need to spend more time tuning them? Or I've got something wrong along the way? I've added and removed foam until I've got what I consider to be a good sound (too much foam meant no bass, to little sounded a little sloppy/flappy) And I would like them to end up as a 2 way system as I think the treble is a little harsh at the moment. But I'm just confused that some tracks seem to have no bass on them..... Does anyone have any experience with them? |
#2 |
frugal-phile(tm)
More info please. Driver, TL plans, amp, room.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Driver is a B3N from IPL Acoustics, do you need the specs? Fs is 77, Qts 8.6, I didn't take anything else into consideration, but since making I've learnt a bit more about Qts and the BL too
TL is small, tried to upload a pic but they are about 3meg in size, tuned to 77Hz which is the drivers Fs, line length 1.05m folded into 4 Amp is a Teac, just a standard all in one, I dont go for seperates or anything fancy at the moment Room is approx 14x12 foot, all hard surfaces, one sofa |
#4 |
Are you sure those track have much bass? Listen to them on another system. To me, most music, that is not heavy in the bass, sounds just full and good on a FR, the bass blends in so well it is part of the music and does not stand out.
Also make sure you are in the EXACT same place when you listen. Even a small difference might put you in a node in that blank room. |
#5 |
I had similar experience with my no measurement and simulation project
I suspecct that it is issue with high second imp. peak of TL ! With some more damping attempts you may change behavior od your TL and get more defined upper bass sound! I meant to increase damping of the cabinet, or change the density versus different areas P.S. sorry for my english
#6 |
frugal-phile(tm)
This one? https://www.madisound.com/store/prod...oducts_id=1503
What does the line look like. What x-section? dave
#7 | |
I messed up a bit with the xsection as I read from the speaker above on the chart, and I used my own measurement of the speaker area and put the area at 19.c when it should have been 30cm2, though I dunno how they come to that number, it doesnt curve that much. Got some pics now do all posts have to go through a mod? fordiyaudio02.jpg fordiyaudio01.jpg |
#8 |
Ah! I don't believe there's nearly enough stuffing in there, and of the wrong density too, I'd imagine. I have larger TLs, and note the same thing as you - I'm going to go into them next week with some (more) old pillows and see what's afoot, measurement mic will arrive also soon and so I'll see if the over-powered low end is coming from a) the TLs themselves or b) just a room resonance.
You might try to stuff it more like this : ![]() I have that driver as my mids, yikes! I must try a wee TL with its larger brother (B4) soon. L
http://blog.liammartin.com |
#9 |
The line is too long even un-stuffed for a 77 Hz tuning, it needs to be around 87 cm long, so once damped it basically has a large sealed cab's response.
That said, its Qts is high enough that a ~89.5 Hz tuning yields the widest ~flat BW, so you may want to consider building new cabs. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#10 | |
I've gone off the usual 1/4 length and lopped off a 5% that I read somewhere to do with the way the port interacts with the room? 87cm to me seems very short, My next project was with some Fs 90Hz speakers and I worked that out to be a 90cm line, though I've not started buillding them yet. How does the Qts affect the tuning? I may have another play around with the stuffing, though it seemed to be a bit flat with more stuffing in, there wasnt the big drop in bass I get at the moment. I want to keep asmuch of the bass as poss!! |
| Finished desktop tl (henkjan/juoiga) alpair 5 | _henry_ | Full Range | 17 | 29th December 2010 05:33 PM |
| TAD TL-1601a and TL-1201 Crossover Point | manp111 | Multi-Way | 2 | 27th September 2010 07:57 PM |
| Can anyone help TL or ML-TL for Alpair 10 | _henry_ | Full Range | 3 | 31st December 2008 06:31 AM |
| What's the difference between a TL, a ML-TL and a TQWT? | Bricolo | Multi-Way | 82 | 28th August 2008 02:17 PM |
| Finished - Pics of my new TL Speaker :) | Xmax BR | Subwoofers | 4 | 10th October 2006 12:10 PM |
| Page generated in 0.12646 seconds (78.49% PHP - 21.51% MySQL) with 11 queries |
