Troels big 3-way
Troels big 3-way
Old 1st November 2010, 12:58 AM   #1
tamule is offline tamule  United States
Default Troels big 3-way
just finished 1st of pair of Jensen 1071. WOW -the SS 18W/8531 sounds euphoric as a dedicated midrange. Amazing bass too with 10" woofer and no-compromise box volume.
I deviated a little with bass cab dimensions (keeping volume constant) to fit 1 piece veneer for front and sides. I used 1 ohm resistor for tweeter R1011 -not 0.47 as per troels' OK. Boxes are premium birch-ply called "Pure-Bond" from Home-Depot. The front and sides are laminated to 1.75" with extensive matrix bracing. Damping is No-Rez and Acousti-Stuff. All coils are air-core. Caps are Clarity Cap PX,SA,ESA and MR and Jantzen Superior.
thanks Troels for a terrific design ! regards, tom
Old 1st November 2010, 05:45 AM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
The mids are amazing on the 18W8531 when you take away the low bass duties.
Nice build BTW.
No longer DIY active
Old 1st November 2010, 06:53 AM   #3
David Gatti is offline David Gatti  Australia
David Gatti's Avatar
Beautiful work Tamule. Congrats.
Old 2nd November 2010, 11:34 AM   #4
jaistanley is offline jaistanley  United Kingdom
Beautiful speakers...
I have been pawing and drooling over the jensen design recently and seriously considering building some with cnc cut ply in a trans-lam setup. Budget means that I think I am going to build something similar first with more conventional boxes and much cheaper drive units.. Something like the Peerless SLS 10", Vifa 17W and a pair of Scanspeak D2905/9000's that I have already picked up from ebay ultra cheap.
Do you have any more photo's and details? I'd love to see how you approached the build.
Jai Stanley
Old 2nd November 2010, 11:11 PM   #5
here are pics of progress so far with 2nd of pair. The woofer coil is mounted with 4 heavy gauge tie wraps through bottom panel. the rest of x-over parts are loosely placed just to give a rough idea of placement. the large caps and coil were accounted for during dimension calculations. the slots around panel perimeters are for biscuit joints. the extra panels are laminated on sides after inner shell is complete. I do all cut-outs AFTER veneering.
Glue used is Gorilla-Glue which allows plenty of application and assembly time before cured. also 100% waterproof. Enjoy, tom
Old 22nd November 2010, 09:33 AM   #6
soundengine355 is offline soundengine355  Australia
Very nice build Tamule!
I am tempted by this design too, however just the drivers alone are approx $2500-$3000AUD plus all the crossover components.
Keep the pics coming!
Old 22nd November 2010, 09:34 AM   #7
Nice build BTW.
Rabbitz, whats your latest audio DIY in the works?
Old 22nd November 2010, 10:03 AM   #8
rabbitz's Avatar
Recently finished a Baby AKSA power amp and a LM4562 based pre.
I have one more speaker to build using the 810921 tweeter and XG18 mid woofer but lack a bit of motivation to commence as it's for the workshop..... one day. It will be a bit like a stage monitor speaker which will be wide but short so it can hang from the ceiling. Drivers will be at 45 to reduce box height so I don't hit my head when walking around.
Old 22nd November 2010, 06:48 PM   #9
tungsten is offline tungsten  Denmark
Terrific build, Tom!
Did you make a dedicated tube for the cables to the mid/treble unit? Or do they just pass through the bass chamber?
Old 29th November 2010, 12:47 AM   #10
the mid/treble crossover is in the bass cab . the cables then pass out of the bass cab -into the mid cab and drivers.
Troels big 3-wayHide this!Advertise here!
Troels CNO25 DanSki Multi-Way 19 5th May 2011 10:59 PM
TJL3W by Troels miamiphoto Multi-Way 1 26th June 2010 05:39 PM
Troels ATR blue934 Multi-Way 22 25th September 2008 09:32 PM
Quick ? on a Troels design ... TurboFC3S Multi-Way 3 15th September 2008 05:17 AM
Troels VS. Zaph - 2 Way Bookshelf Showdown harrisni Multi-Way 24 2nd April 2008 04:40 PM
