Where Can I Buy Neo10
Old 6th November 2010, 12:08 AM   #11
studiotech is offline studiotech  United States
Originally Posted by DQ828 View Post
I have done the deal with Danny, drivers on the way
Congratulations! You made a good choice to spend the extra $ for them over some other cone drivers. Good luck with your build.
Greg
Old 6th November 2010, 02:02 AM   #12
ScottG is offline ScottG  United States
Greg
I second that!
perspective is everything
Old 6th November 2010, 10:38 AM   #13
DQ828 is offline DQ828  Australia
DQ828's Avatar
Default Baffle Width for Neo10
This probably isnt the place to ask, but ask I will. Has anyone got an idea of the reccomended baffle width for the Neo10. Planars dont appear to have the same paramenter as standard driver, & the software I have needs parameter to work.
If worst come to worst it will be trial & error, I'm usually good at the error part
David
Old 6th November 2010, 01:32 PM   #14
fabel is online now fabel  Germany
fabel's Avatar
Hallo David,
you can simulate the influence of the baffle even on recatular drivers with the wonderfull tool "Edge": Home of the Edge
Good luck and much fun on your built
Fabian
Old 6th November 2010, 02:16 PM   #15
dabbler is offline dabbler
I was dissapointed with the neo3's - curious to know how the neo10's will sound...
Old 7th November 2010, 12:19 AM   #16
DQ828's Avatar
Shame about your timing on that comment.
Old 7th November 2010, 12:35 AM   #17
DQ828's Avatar
Originally Posted by fabel View Post
Hallo David,
Fabian
Thank you, have downloaded & am playing
Old 7th November 2010, 12:50 AM   #18
If you do a search on *all* of the smaller BG planars you'll see a wide variety of opinions.
This is almost exclusively do to implementation.
Any time you use a rear chamber on the drivers you are likely subjecting them to compromises in overall sound quality.
Any time you use them open baffle they are HUGELY dependent on the baffle and summing with other drivers.
On top of all this the larger drivers not only have a rising response, but they also operate as line-sources at higher freq.s..
Old 13th March 2011, 02:53 PM   #19
otto88 is offline otto88
otto88's Avatar
Originally Posted by Danny View Post
I have had them in stock for the past year and a half.
I can see the Neo3 and the 8, but not the 10 - now out of stock?
Old 13th March 2011, 10:52 PM   #20
Danny is offline Danny  United States
Send a message via AIM to Danny
In stock just on the web site.
www.gr-research.com
Where Can I Buy Neo10Hide this!Advertise here!
BG Neo10 and Raal 140-50 measurements studiotech Planars & Exotics 1 19th September 2010 11:05 PM
bg neo10 clone NurEinTier Planars & Exotics 3 28th February 2007 10:51 PM
B&G Neo10 planar ? cph2000 Multi-Way 0 12th September 2005 09:15 AM
Copyright ©1999-2017 diyAudio
