Old 29th October 2010, 02:02 AM   #1
Red face Need guidance, first spkr plans.
Hey guys, I'm new here. May I say great site?
I designed this spherical 2.1 speaker set and I'd like some input on my choice of components and how to crossover.
Total component list.
4x Aurasound NS3-193-8A 3" Extended Range
https://www.madisound.com/store/prod...products_id=83
F3 of 85Hz: 2 to 3 liters sealed and stuffed
2x Fostex FT17H Horn Super Tweeter
https://www.madisound.com/store/prod...roducts_id=286
1x Peerless 835017 XXLS 12" Aluminum Cone 4 ohm
https://www.madisound.com/store/prod...oducts_id=8636
2.5 cubic foot box with a 3" diameter vent by 13" long for an F3 of 30Hz
As far as plans go, they will be hooked to a DC powered amp and dac, via toslink to my pc. I'm trying to find an automotive amp rated for 8ohm for the speakers and 4ohm sub. I want the sub to handle up to 100hz, mids from 100hz-5khz, tweeter 5k-25k.
OK guys, hack away
3rd rev, tweeter more inline with woofers
Old 29th October 2010, 03:19 AM   #2
the supertweeter is way more efficent than the mids, not a good match;
for power handling and baffle step correction, I'd look at crossing your woofer over higher, how wide will your mids cabinet be? - this determines the baffle step freq.
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 29th October 2010, 03:40 AM   #3
tinitus is online now tinitus  Europe
its sure a hell lot of work
might make more sense with better drivers
80db sensitivity is very low
maybe skip the MTM design
one good mid and one tweeter might give you a better chance
especially with the spherical mid design
best to have the tweeter slightly "behind" the mid, which would come natural with the spherical design
Old 29th October 2010, 01:10 PM   #4
Checkout the info on small drivers on Zaphs site, and small tweeters.
rgds, sreten.
undefinition
Zaph|Audio
FRD Consortium tools guide
RJB Audio Projects
Speaker Design Works
HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs.
Humble Homemade Hifi
Click below to go to
Quarter Wavelength Loudspeaker Design
The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs
Linkwitz Lab - Loudspeaker Design
Music and Design
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 29th October 2010, 05:11 PM   #5
Thanks for the replies fellas. Doing some rethinking. How do you think a pair of lines of those woofers would sound? I'm thinking 9 per side arranged in a vertical arc for equidistance from my ears. Comb filtering shouldnt be an issue with a fixed listening position.
I've been flip-flopping between a multi-way / line design for weeks..
Spkr A/B switch -- matching sensitivity, etc redrabbit Multi-Way 9 28th December 2008 07:29 PM
full range spkr sensitivity audiotang Full Range 16 6th August 2004 10:19 PM
Spkr Box Panel Thickness richie00boy Multi-Way 11 8th July 2004 08:34 AM
My center spkr. How do I equalize for...? Lito Multi-Way 3 21st December 2003 02:44 AM
Page generated in 0.11146 seconds (67.74% PHP - 32.26% MySQL) with 11 queries
