Vas Question
Vas Question
Old 31st December 2017, 09:21 AM   #51
multi is offline multi  Australia
i have 515 8ghp qts .195; I use tube amps damping factor about 10 to 12DB. At the moment I am trying Chinese speakers with QTS of 0.283 sensitivity of 99 db
phil
Old 2nd January 2018, 01:17 AM   #52
head_unit is offline head_unit  United States
Originally Posted by 33Polkhigh View Post
Can anyone tell me if you add series resistance to a driver to raise its qes, does this affect its VAS. I would assume that vas takes qes into account when its calculated, but does anyone know how this works?
To rephrase what Ron E said, Vas is just determined by the suspension (spider + surround).
Generally I'd say adding series resistance is not a good way to achieve things, to me it indicates the driver is not the right driver.
Old 2nd January 2018, 11:00 AM   #53
33Polkhigh is offline 33Polkhigh  United States
Yea, I was looking at some full rangers like the audio nirvana classic 5". Raising the qes you can easily get sealed -3db in the 70-80 hz range, which is decent, plus the other benefits of sealed. I always use equalizer APO anyways so dealing with the changes to frequency response wouldn't be a big deal, but I haven't tried it.
Old 4th January 2018, 03:50 PM   #54
You mean this thing
Audio Nirvana Classic 5 Fullrange Speaker Driver
I presume. So in a small sealed box, if you made the Qts 0.7, the Fc becomes like 150 or whatever-and it seems to me what you want to do is raise the Q so you get the Q you want without raising Fc. Hmmm. Maybe...sticking a resistor in series just sticks in my engineering sensibilities, since it wastes power and my gut feel is "it doesn't really work like that" though I cannot definitively say that is so because it's a long time since I thought about doing that.
It becomes kinda sorta like a high output impedance tube amp, screwing up the frequency response, and around resonance screwing it up in a dynamic way since the Thiele-Small parameters change with the drive signal magnitude. It would also reduce the whole sensitivity since you're padding down the whole speaker. But it is easy enough to try as an experiment.
Old 5th January 2018, 12:36 AM   #55
GM is offline GM  United States
GM's Avatar
Raising the qes you can easily get sealed -3db in the 70-80 hz range......
Right, trading efficiency for a wider effective bandwidth [BW], so EQ can only do so much before running out of power handling.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th January 2018, 12:44 AM   #56
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
GM
Or running into xlim/xmech even.
Old 5th January 2018, 01:00 AM   #57
GM's Avatar
True, these are normally the dominant part of 'power handling' in the LF.
GM
Old 13th January 2018, 01:47 PM   #58
Using series resistance to change impedance lets you use drivers with powerful magnets and light cones in alignments that wouldn't normally suit them. Even using an over damped full ranger in an open baffle. I'm assuming you get the dynamics and detail. A lot of high q drivers have heavier cones or somewhat weak motors.
I wouldn't mind trying it and audio nirvana classic, maybe with a ribbon tweeter on the side. But I don't have room for any more speakers.
Yea the shorter xmax limits max volume, or requires a sub.
Vas QuestionHide this!Advertise here!
A superior VAS clamp and VAS current limit for the Blameless. GK Solid State 128 19th October 2011 03:03 PM
Question.. 2 Drivers in series, is there a change in Vas? 2 times?? mdenismd Multi-Way 10 16th August 2010 11:11 PM
Vas question 3-LockBox Multi-Way 4 28th June 2007 06:51 PM
low VAS sealed better than high VAS? matos81 Subwoofers 3 7th April 2006 11:28 AM
VAS to LTP Feedback Capacitor Question (A bit like in the A40) primalsea Pass Labs 1 15th November 2005 09:31 PM
