Need advise: 1x12" plus 2x15" organ speaker
Old 27th October 2010, 09:53 PM   #1
platplaas is offline platplaas  Canada
Default Need advise: 1x12" plus 2x15" organ speaker
Hi - I am able to buy an old organ speaker cabinet with 2x15" speakers and 1x12" speakers. No specific info is available on the make or model of these speakers. Can anyone identify anything from these pictures?
Any chance these are full range speakers? I'm wondering if the 15" speakers may be of use in building a full range baffle... ?
Thanks.
Old 27th October 2010, 10:05 PM   #2
DQ828 is offline DQ828  Australia
DQ828's Avatar
Thanks.
They look similar to old isophon speakers, I dont have the info with me but will have look when I get home.
Old 27th October 2010, 11:19 PM   #3
I googled images for organ speakers and looks like these are Magnavox 12" / 15" speakers with alnico magnets - any ideas on sensitivity of these speakers and frequency range?
Am I nuts for thinking of using the 2x15" as full range speakers for a small tube amp??
Old 27th October 2010, 11:55 PM   #4
More info when searching for Jensen vs. Magnavox. Not sure the difference?
Old 28th October 2010, 01:21 AM   #5
PeteMcK is offline PeteMcK
there should be a manufacturers code on them somewhere, this will give manufacturer and date once interpreted, (you should be able to find a list on the net, Planet10 may be able to help). re:'Am I nuts for thinking of using the 2x15" as full range speakers' - yep, probably, but they'd probably be good as woofers in an OB...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 28th October 2010, 02:52 AM   #6
DQ828's Avatar
I wise I had them, I bet they could give you some great bass, maybe some mid but cant imagine you'd get much usable hi frequencies out of them, unless there coaxial.
Need advise: 1x12" plus 2x15" organ speakerHide this!Advertise here!
"Phantoms of the Organ" Halloween bash bentoronto Subwoofers 24 31st October 2015 07:13 PM
Bad Tube in my "new" Hammond C2 Organ preamp? HELP w/ diagnosis!! jeffstev Instruments and Amps 10 24th November 2011 06:59 PM
1x12" guitar speaker cabinet hornloaded Instruments and Amps 7 9th February 2010 11:48 PM
2x15" help... eppidrummer Subwoofers 2 8th March 2008 03:16 PM
18" or 2x15" for OB barackuda Multi-Way 8 19th September 2007 08:27 AM
