I just want to conform from other members here that does Lpad attenuator affect sonic quality of tweeter. I tried a tweeter with 6db Lpad attenuator another without attenuator. but reduced the same db at amplifier to match the output at tweeters. what I felt was the tweeter without Lpad, Sound better crisp and clearer, and sound more natural.
Just want to know from you all here is , what difference I heard, makes sense or just my illusion. Also is some body can explain how series resister in attenuator makes the difference. resister in series of any driver affects the damping of driver. so how this affects tweeter? Regds
There is always a first time.... |
#2 |
It is difficult to judge that way.
You shout compare the one with l-pad to the one with out at the same loudness level. And then in a blind test say if you really can hear the difference. My self I do think I hear difference between wire wound resistors and metal film. To me the wire wound sound brighter but it tents to more aggressive. So I compared wire wound to metal film and carbon resistors.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 22nd October 2010 at 07:45 PM. |
#3 |
Hello,
if you have a passive crossover (high pass filter) for the tweeter, the L-Pad's effect on the tweeter's impedance in the resonance region may change the rolloff behaviour of the high pass because the tweeter's impedance peak at resonance is mitigated. Typically the tweeter can have somewhat lower relative level now around its resonant frequency if the L-Pad was designed to maintain the tweeters DC resistance. Depending on the tweeter and dimensioning of your L-Pad the slope of the crossover will be closer to theory - resistive load - now since the padded tweeter is closer to a resisitive load. The damping (electro motoric force) for the tweeter at its resonance might even be higher than without L-Pad, depending on your high pass filter... So it may sound different now, but that need not be a degradation. Maybe the filter should be corrected ... I do not believe in sonic degradation caused by an L-Pad if L-Pad and filter are dimensioned properly. Many in here believe resistors being "sonic poison" in itself, i do instead believe resistors being the most harmless components in a passive crossover, as long as effects on level, damping and the like are accounted for ... If you have the possibility of circuit simulation and your filter is 2nd order, you can try 1) ---ccc----rrr---twt---| ..........|......|--rrr---| ..........|--------llll---| 2) ---ccc----rrr---twt--| ..................|--rrr--| ..................|--llll--| with ccc: capacitor rrr: resistor llll: inductor twt: tweeter option 2) which may provide somewhat more damping (emf) for the tweeter in the rolloff region of the filter. Kind Regards Last edited by LineArray; 22nd October 2010 at 08:35 PM. |
#4 |
The series resistance will also change the TS-parameter of the tweeter maybe this makes the difference.
Also the damping factor of your amplifier reduces due the series resistance.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet |
#5 |
Yes, option 2) may bring a little damping back,
since the coil can better contribute as a shortcut across the tweeter's terminals in the lower rolloff region. Next option is full impedance compensation of the tweeter's resonance before applying the L-Pad. Last edited by LineArray; 22nd October 2010 at 08:55 PM. |
#6 | ||
Thank you all for the prompt reply.
I was out of town as my uncle died. Sorry for the delay. Quote:
I did so, I guess u missed those lines in my post. LineArray: I never thought of what you explained. I mean in this case. Sure L-pad makes crossover resistive load. but in that case, can we say Crossover would perform better? I never tried but just thinking. what if L-pad is added before crossover and tweeter? any Idea? Quote:
"The series resistance will also change the TS-parameter of the tweeter maybe this makes the difference. Also the damping factor of your amplifier reduces due the series resistance."
#7 |
The L-Pad usually goes after the crossover as it means a flatter impedance curve and damped resonance (as noted above). This is often quite desirable.
But in your case it may not be. Try it the other way around - it may work better with your tweeter and crossover.
Take the Speaker Voltage Test! |
#8 | |
also affected by the series capacitor, which has a much higher impedance than the tweeters Rg in the crossovers rolloff range and the crossover frequency is typically fairly above the resonance of the tweeter. Every circuit has to be investigated individually, concerning the resulting Qes ... it depends on the tweeter's properties and the whole crossover circuit. But it is impossible to make the tweeter "see" the amplifier in the rolloff region of the crossover, there will always be a high impedance in series, with resistive component or not. The question - besides going active - may be: Where do we get damping ? One option is to make Qm lower and apply mechanical damping (e.g. by a large rear chamber and a flow resistance behind the membrane) to the tweeter to get the desired effective Qts. Another option is to provide some low electrical impedance in parallel to the tweeter especially in the rolloff region of the crossover, which provides some damping by back EMF. For purposes of back EMF solely it is not important, whether the current induced by the tweeter's moving voice coil flows through the amplifier ("which is ideally a wire with amplification") or through a (low) impedance parallel to the tweeter. But you won't get that impedance very low - just as low as possible. If one does not want to compensate the resonant impedance peak of the tweeter using an LCR in parallel to the VC terminals, also a resistor in parallel can be used to make the load more resisitive and damping more frequency independent. You can use that even without series resistor, which means without padding the tweeter down ... That will cost some efficiency ( not voltage sensitivity) but the crossover slope will be closer to the "resistive load" case. Especially with a tweeter of relatively high impedance this may be an option. Kind Regards Last edited by LineArray; 27th October 2010 at 01:53 PM. |
#9 |
Guys I am experimenting..... Working on it... Will update you. Thanks for being with me...
| XLR audio pad attenuator | frenchie29 | Instruments and Amps | 0 | 1st May 2009 09:44 PM |
| is L-PAD attenuator recommended for a 6 1/4 midbass? | rhythmdiy | Multi-Way | 5 | 31st October 2008 01:49 PM |
| Attenuator L-Pad switch to simple resistor problem | mudakas | Multi-Way | 3 | 13th September 2005 08:03 AM |
| High quality 16-ohm L-pad and/or alternatives? | Alidore | Multi-Way | 4 | 19th May 2004 08:21 AM |
| Page generated in 0.12064 seconds (81.61% PHP - 18.39% MySQL) with 10 queries |
