Old 11th July 2003, 02:03 PM   #1
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Question Diffraction/Rounded Baffle
On the Curve Sided Loudspeaker page posted a short time ago, the transverse lamination examples have flat baffles...
I want to incorporate this lamination method into my design but was wandering why the enclosures shown have stopped short of going for a full rounded baffle - which would have helped further reduce diffraction effects. Or is this incorrect?
Old 11th July 2003, 02:42 PM   #2
7V is offline 7V  United Kingdom
7V's Avatar
Default Re: Diffraction/Rounded Baffle
Personally, I went as far as I could with the rounding. Just couldn't get round the fact that you need a flat surface to mount the drive-units to.
Other than that, you have to juggle height, depth, width and wall thickness to end up with the right volume.
Good luck with your Translams, Vikash. Post us any drawings or photos when you have them.
Steve
Old 12th July 2003, 01:56 AM   #3
Vikash's Avatar
Hello Steve,
...need a flat surface to mount the drive-units
Just thought i'd bounce an idea of you...
The driver would only be flush on part of the baffle. Don't know if i'm gaining something or losing something. Certainly looks cool
Old 12th July 2003, 02:22 AM   #4
7V's Avatar
And is that an egg shape inside?
I love it.
Old 12th July 2003, 02:31 AM   #5
Vikash's Avatar
Still awake and on the forum like a true fanatic i see
It's egg all the way! Outside for diffraction, inside for standing waves.
Old 12th July 2003, 02:45 AM   #6
7V's Avatar
Stunning. What's the driver?
Old 12th July 2003, 02:53 AM   #7
Vikash's Avatar
I've decided on the Seas W22EX002. Tweeter yet to be decided. Choices are reduced due to the low cut off required for the mid range. And it doesn't help that I have no crossover designing experience. Well, one thing at a time.
It's as much about the journey as the ending right...
Old 12th July 2003, 04:44 AM   #8
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
The downside of course are the sharp edges in front of the driver.
I guess I would have a short cylinder extending out to the frontmost edge of the curved baffle so the top and bottom of the cylinder would extend the same as the baffle but the sides would be a couple of inches long. Then mount the driver in the end of the cylinder. Inside and outside eggs seem the way to go....
Old 12th July 2003, 05:16 AM   #9
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Heavily chamfer the front edges to the driver? Do that, and you won't have egg all over your face.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 12th July 2003, 07:06 AM   #10
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
correct me if I'm wrong, but the sharp edges in front of the driver won't be *much* of a problem if the driver is crossed over fairly low...
though, if you're going for full-range, maybe that's not an option.
*shrug*
Baffle diffraction step - is this right? buzz1939 Multi-Way 6 6th May 2007 06:55 PM
Qs about baffle diffraction elambert Multi-Way 1 30th November 2005 10:09 PM
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 12 12th January 2004 04:43 AM
Can a baffle diffraction do this to an OW1 harvardian Multi-Way 6 30th December 2002 08:31 PM
Page generated in 2.40339 seconds (3.72% PHP - 96.28% MySQL) with 11 queries
