Old 19th October 2010, 01:58 AM   #1
Send a message via MSN to SergeDufour
Default Holm Impulse analysis Scanspeak speakers
I built my speakers based on a scanspeak design (see pict)
I hooked up the holmimpulse-measurements software and my laptop to my sound system and a nice Rode NT1A microphone. My towers are two ways, with two woofers and one tweeter that I built. The output is impressive and the plot too !
The result of the holmimpulse analysis (pict) is impressive but whatever is the deviation, how ones make those so called corrections to the speaker ? I love the way it sounds but if I can improve it further....
I cannot change the crossover because its design is according to specifications. I can certainly put more or less damping material inside the tower as well as changing the aperture which is toward the floor.
Advices ?
Old 19th October 2010, 02:17 AM   #2
jr is offline jr  Australia
Judging by the frequency response plot, there seems to be something wrong with either your measurement setup, your speakers or both.
Old 19th October 2010, 02:39 AM   #3
It looks like you have some bad measurements. Check the gating and set it to about 700 hz. Measure from about 6 or 7 feet from the speaker. Make sure only one speaker is playing. Move the speaker away from any walls or objects. Turn off the phase graph too. Post a new graph. Look only at the response above 700 hz. (for now.) You may have a sound card setting issue.
Old 19th October 2010, 03:42 AM   #4
The Rode Nt1 is not really suitable as a measurement mic unless you can make a calibration file for it. See freq response here:
http://aus.rodemic.com/downloads/nt1..._datasheet.pdf
Greg - tech - www.phatplanetstudios.com
Old 19th October 2010, 02:08 PM   #5
Pano is offline Pano  United States
Pano's Avatar
Agree with the above, you've got some problems. Be sure to run just 1 speaker at a time. You might also try 1/6th octave smoothing on the plot. It's in a pop-up when you click the "options" button.
Old 19th October 2010, 02:42 PM   #6
scott wurcer's Avatar
Greg - tech - Phat Planet Recording Studios - Orlando Florida - Audiophile Quality Recording, Mixing, Mastering, Production
I agree, the Rode is a large diaphragm mic and is not flat enough to use without cal and is also not omnidirectional. You would be better off with a small omni capsule mic.
2012, our time is running out.
Old 19th October 2010, 03:17 PM   #7
I just realise my mistake. My mike is really a Rode NT-2a which is patern selectable, so yes omnidirectional.
And about its response : seems pretty flat to me (see pict !)
Old 19th October 2010, 03:50 PM   #8
Pano's Avatar
It's certainly much flatter than your measurements!
Just remember the bump at the top when you measure.
Old 19th October 2010, 03:53 PM   #9
doug20 is offline doug20  United States
The plot looks like it has lots of noise to me. Did you run sound card calibrations? Do you have them saved and checked before running measurements.
Your impulse should more look like this...it should not have noise in it.
Old 19th October 2010, 04:56 PM   #10
Paul W is offline Paul W  United States
Paul W's Avatar
Was the crossover design optimized with actual driver measurements on your baffle?
Paul
Scanspeak Speakers now at Hasaudio hasaudio.co.nz Vendor's Bazaar 9 17th November 2010 04:12 AM
3 x Scanspeak d2905-9500 18w8545k-00 speakers i4gotmyid Swap Meet 1 5th November 2008 03:18 PM
Building new speakers, FOCAL or SCANSPEAK ? jomor Multi-Way 29 10th August 2004 08:50 PM
Custom unfinished Scanspeak/open baffle speakers Ric Schultz Swap Meet 0 5th March 2003 09:33 PM
Impulse Control BAM Multi-Way 0 28th February 2002 12:46 AM
Page generated in 0.18891 seconds (49.45% PHP - 50.55% MySQL) with 11 queries
