Old 10th July 2003, 04:48 PM   #1
Ian J is offline Ian J  United Kingdom
Default Cabinet materials - why not more diversity?
Hi all,
Most speaker cabinets are made from Mdf or ply as this is good solid stuff that's not too hard to work with, and has the mass to attenuate the sound. But is this mass necessary? There has been at least one attempt (Acoustic precision) to make a cabinet with expanded polystyrene (styrofoam in the US?). This used a single Jordan JX92 and got good reviews, though it apparently lacked bass. Polystyrene is light but rigid, and the lack of mass means it stores less energy therefore there's less colouration of the sound from that energy turning into panel resonances. Aren't there other materials that might offer similar benefits of being lighter and easier to work with than wood? Mind you I've no idea how you would actaully mount a driver in a polystyrene baffle, presumably that has to be something stronger. And too little mass might reduce the dynamics due to movement under Newtonian force... I'll stop here before I demolish my own argument.
IJ
Old 10th July 2003, 05:38 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
Concrete
Marble
Stone of other kinds
Glass
Lumbercore
Plexi
Metal with damping
Lot's of materials.....
/Per-Anders (my first name) or P-A as my friends call me
Old 10th July 2003, 06:11 PM   #3
here's a thread
Mr. Pass has some with granite front baffles. or is it marble...one or the other anyway.
i want to see some speakers made with Corian. anybody got any pictures?
/andrew
Old 10th July 2003, 06:33 PM   #4
uli is offline uli  Austria
Wilson uses porprietary VERY heavy materials...
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 10th July 2003, 06:42 PM   #5
Bricolo is offline Bricolo  France
Bricolo's Avatar
how do you assemble cabinets made of stone?
Old 10th July 2003, 07:08 PM   #6
Send a message via MSN to Tazzy
Euhm, like a real pro?
Old 10th July 2003, 08:44 PM   #7
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
There is this one, but I was thinking it might be fun to try a Corian composite dipole. (Smallish to min. $$):
http://www.pioneerelectronics.com/Pi...22,590,00.html
System Center Channel Speaker : TZ-MC09 : $350.00
The Elite TZ-700 system speakers prove that an elegant and interesting design can be combined with high performance. The system includes a 3-way subwoofer with a 7-ply cabinet and integrated 300-Watt amplifier. The slim surround speakers allow you to re-position the tweeter for better room coverage. And the center channel speaker- which reproduces center-stage action like movie dialogue- is designed to sit on or near the television and complement its shape. All together, an elegant and powerful surround sound system.
Corian Material Construction
Bass Reflex cabinet, Satellite / Bookshelf Style
Linear Power Response Technology
2 Way 3 Speaker System
3 " LPR Woofer, 1" Tweeter
Frequency Response: 70Hz to 60 kHz
Sensitivity 86dB / 1 watt / 1 meter
Maximum Power: 150 watts
Crossover Frequency: 8,000Hz
Video Shielded
Speaker Terminals: Banana Plug Ready
Cabinet Color: Corian Stone Finish (05)
Old 10th July 2003, 09:59 PM   #8
yes, all this 'heavy' stuff is interesting, but I was more interested to see if anyone has tried light materials/composites for the cabinet. Is there a real physical reason why there has to be alot of mass in the cabinet to attenuate the rear wave? I remember reading somewhere that there are frequencies where mdf is much more 'transparent' to sound than at others, do all materials behave similarly?
Ian
Old 10th July 2003, 10:18 PM   #9
7V is offline 7V  United Kingdom
7V's Avatar
Didn't Celestian come out with some lightweight cabinets some years ago? Aerolam or something?
Call me old fashioned but I reckon that if you can lift it easily, it ain't hi-fi.
Steve
Old 10th July 2003, 10:25 PM   #10
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Yes, light materials can be used, but they tend to be quite difficult to work with. You probably remember the Celestion SL600 which was effectively an SL6 in an Aerolam aluminium honeycomb cabinet. Light materials have the attributes you describe but jointing is tricky, and a special bayonet mount was needed to spread the load when fitting the drivers. Another composite possibility is Formica/expanded polystyrene/Formica. Again the problem is the jointing and driver mounting.
It is possible to make a light, rigid box that has its structural resonances much higher in frequency than the standard MDF shoebox, but it's trickier.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Ultimate DIY cabinet materials? VvvvvV Multi-Way 63 1st March 2010 09:05 PM
Cabinet Materials Justin Melhado Multi-Way 3 20th January 2008 11:18 PM
Cabinet materials Solid Snake Solid State 2 16th November 2003 11:17 PM
cabinet materials biff584 Multi-Way 11 4th June 2003 05:51 AM
Exotic cabinet materials being considered... should i bother? akiwiskibum Multi-Way 4 19th September 2002 01:02 AM
Page generated in 0.12596 seconds (77.26% PHP - 22.74% MySQL) with 11 queries
