A bass-boost circuit for OB - Page 5 - diyAudio
Old 5th October 2012, 08:44 PM   #41
kees52 is offline kees52  Netherlands
Originally Posted by Roushon View Post
Thank you for using the circuit and I am happy that you found it good for your setup.
Roushon
Hi All
I go lower the input resistance to 100k what is used most I think.
Here I give the input tube preamp, maybe someone can give some more clearance for me I have for sure more bass and better, but I need a correction in the 30 hz range, so let me now. I don,t want use opamps I have tube hybrid design so it is a line level schematic..
Now I have a tube input with 1 meg resistor so output impedance is high, I change the resistor for 100 k now and test, I have read that output impedance may be high but input low, in my case 2k.
thanks again.
Bass Boost Circuit metal Chip Amps 0 15th November 2005 09:29 PM
bass boost odysseybmx414 Chip Amps 3 26th August 2005 10:05 AM
shivas sub& bass boost circuit busterno1 Subwoofers 7 1st September 2004 09:02 AM
bass boost lawbadman Solid State 4 29th August 2003 03:20 PM
simple bass boost circuit deepanger Solid State 11 28th December 2002 02:37 PM
Copyright 1999-2017 diyAudio
