#51 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#52 |
Dave:
I didn't know that Qts for Transmission Line was so different from the vented box. Perhaps BAM would like to try his hand at the Transmission Line, after all.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#53 |
Okay, guys, you are going to have to bear with me.
Subwoofer Simulator and the rest of the freeware normally does not model pipe resonances. I am downloading Unibox. I am learning Unibox. Unibox might or might not model pipe resonances. I am also thinking of downloading Martin King's Transmission Line program. The problem is finding a free version of MathCAD-he doesn't use Excel. I wonder, does Martin L. King's program contain a way of modelling a chamber on top of the Transmission Line? For that is what a Daline is-a chamber on top of a Transmission Line. I shall try Martin L. King's site and see what happens.
#54 | |
frugal-phile(tm)
http://sliunix.lanecc.edu/~jamies/mcexp802.exe Martins model handles a daline with no problem. You need to use the sevtions version of the worksheet. Martin also has the 1st of his alignment tables (each table has to restrict the lines geometry to work), which can get you in the ballpark real quickly (daline isn't covered in these yet) dave
#55 | ||
It has two 0.5mH inductors in series, so figure ~0.7ohms of series resistance using a large gauge, upping Qts to ~0.332 using the 5NV4211DB's published specs. Quote:
Anyway, looks like whoever designed this did themselves proud with this one, and assuming you accept my analysis, should give you enough insight to adapt it to other drivers. HTH, GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#56 | ||
Well, phooey!
Decided to input this into MLTQWT and noticed I'd used 0.3 instead of 0.23 for Qes, skewing everything, so ignore my previous post.Quote:
It has two 0.5mH inductors in series, so figure ~0.7ohms of series resistance using a large gauge, upping Qts to ~0.26 using the 5NV4211DB's published specs. Quote:
Anyway, looks like whoever designed this did themselves proud with this one, and assuming you accept my analysis, should give you enough insight to adapt it to other drivers. HTH, GM Addendum: plugging the numbers into the MLTQWT spreadsheet shows a typical resonant pipe that would be less so with damping in the vent pipe per the spec, F3 = ~33Hz, Fb = ~28Hz. It appears that what I considered a worst case scenario for how much the BH5 affects the dims turned out to be not conservative enough if the published specs and my assumption as to how much series resistance there is ~accurate. Anyway, eschewing all this and calculating a Daline my way using the 0.26Qts and Fb = Fs, taking the max flat 0.13Vb and increasing it 1.414x I get a rear chamber of ~0.1837ft^3, or a ~golden ratio 11.03"h x 6.82"w x 4.21"d.. Maintaining the same driver vertical spacing, the woofer is 7.25"/11.03" = ~0.6573*L. Using a pipe area = ~Sd equates to 13.423in^2/6.82" w = ~1.97" d.. Actual pipe length = ~13560"/4/40.4Hz = ~83.91"- 11.03" - (13.423/pi)^0.5 = ~70.81". This sims F3 = ~35Hz, Fb = ~32Hz. Works for me.
#57 | ||
I looked up Black Hole 5, and it turned out to be an expensive "viscoelastic" substance similar to Rubatex and other pipe coverings, only more sophisticated, in some way. I decided to treat Black Hole 5 according to author David Weems' rule for damping materials such as polyfill, wool, etc. That is, squeeze the material in your fingers, and see how far it compresses. The compressed volume is what you consider the actual thickness. Well, I have some Rubatex here, I squeezed it, (very soft), and I had no trouble compressing 90% or more. I assume Black Hole 5 is similar. So I considered the actual thickness of Black Hole 5 essentially negligible, as I would polyfill. Regardless of whether Black Hole 5 is like Rubatex or not, it is soft damping material and flexible. In your analysis, you are saying that two inches of Black Hole 5 on the walls is the same as 2 inches of wood. Without having used the product, I would tend to doubt that, although if that has been your experience with it, I wouldn't go against it. Similarly, using the same "Black Hole 5 = wood" principle, you reduced the line cross section from 3.5" x 5" to 2.5" x 5". Again, I cannot say with authority that is not the case, but I would like to know from someone who has used it that this soft, flexible rubber like product is to be treated the same as hard wood for the purpose of computing volume. It seems to me that, on the Line/port, we are dealing with low frequencies, which have a penetrating power, and are much more likely to "see" a difference between a soft rubbery product and solid wood than higher frequencies will. Quote:
#58 |
I don't see how Weems remark is valid WRT something like BH5, and I can only squeeze the foam portion enough to matter, so his 'test' for apparent density is way too 'flexible'
One could argue that the rear chamber 'breathes' around Fb due to the sheer quantity used, making for a ~constant Vb regardless of pressure, but if it does, then the roll off would be more, further lowering the F3, and combined with the modest pressures the driver can generate, dismissed this as irrelevant for reverse engineering purposes. Same for the pipe since the BH5 'feels' the dominant pressure in shear, leaving the foam the major 'drag' on pipe action, with the balance of the BH5 damping the cab's construction. Anyway, none of this was meant to imply that BH5 = wood. WRT measuring a ~constant cross sectional area pipe, right, you measure down the middle, but I believe you forgot to include the bends in your calc.. GM
| Dipole bass or Ripole Bass? | MJL21193 | Subwoofers | 13 | 15th September 2008 07:42 AM |
| any electric bass players? im building a bass guitar cab | KOA | Instruments and Amps | 27 | 30th April 2007 03:49 PM |
| DBA (dual bass arrays) and active bass traps | capslock | Subwoofers | 3 | 20th August 2006 12:52 PM |
| For all Bass Junkies out there (Behringer Bass processor usage report) | VEC7OR | Digital Line Level | 5 | 27th October 2003 09:18 AM |
| Page generated in 0.19192 seconds (58.37% PHP - 41.63% MySQL) with 11 queries |
