Audio Junkie
I have been considering using the Tang-Band W4-930Sf as a midrange driver crossover to a Vifa XT25SC90-04 Ring Radiator tweeter. I had Madisound do the LEAP measurement and figure out a crossover for me. response looks pretty good. Easily manageable.
I plan to crossover to the TB around 200hz and the Crossover point between the TB and the Vifa is 4Khz so the TB has a nice wide range and the x-over is out of the vocal spectrum. there is a bit of a bump at 750hz to be tamed and once the HP at 200hz is there, the low end bump should go away. What do you think? |
#2 |
Audio Junkie
Got my XT25's today. Nice, the're larger than expected.
#3 |
Is that from "canned" curves of actual measurements in your boxes?? If they are not actual measurements in your boxes I would expect some deviation from that curve when you build them.
Rob
"I could be arguing in my spare time" |
#4 |
Audio Junkie
am assuming that is canned curves. Madisound offers a service where you tell them what drivers you want to use. they input the data into LEAP and then figure out what the best crossover point and crossover design is and then send you the data with a crossover design etc. I doubt they put drivers in boxes and test. But they may have tested each driver individually and come up with there own canned data?
| for sale: LinearX Systems Leap-5, LMS-4 & PAC IV, AutoCAD 2008, Mathcad 2001 software | vincentrubble | Swap Meet | 17 | 9th June 2008 01:18 PM |
| Vifa XT25 & XG18 MTM? | EDDIEMUNSTER | Multi-Way | 3 | 5th April 2007 03:18 AM |
| Vifa xt25 & Peerless Exclusive | hc_TK | Multi-Way | 11 | 24th December 2006 02:50 PM |
| The "Leap-Frog" Method Of Switching Amplifier Control Loop Design | analogspiceman | Class D | 29 | 1st December 2006 03:21 PM |
| Vifa xt25 & p13 | Gavinator68 | Multi-Way | 1 | 1st June 2005 06:39 AM |
| Page generated in 0.09121 seconds (63.60% PHP - 36.40% MySQL) with 12 queries |
