#441 |
bellissimo
#442 |
#443 |
Thanks gentlemen.
When I put the 2nd speaker together late last night I forgot to put the infill panel in below the mid driver, so when I went down this morning to wire it up the first thing I saw was the infill panel sitting on the bench, doop. It turned out not to be a difficult as I first thought to put in the panel. I needed to support the body so I could remove two of the bolts holding the body to the box, I thought it was fitting to use a couple of pillows to do it ![]() I am now making the grill covers, I am custom fitting each one to ensure a good fit. I thought I would just build one first as I'm not sure how they will workout, |
#444 |
You sure do good work. Very cool and professional looking. I know they will sound great too.
My "Art" website http://home.comcast.net/~djnagle/site/ |
#445 |
Thanks djn.
Yesterday started ok, did some work on the test grill surround getting ready to cover it. I had the surround ready for covering when I had to duck off the the doctors to have a cyst removed from my back, which I thought was going to be a doodle, I should have known better. After waiting an interminable amount of time the doctor was finally ready to see me, well as it turned out he didn't know why I was there & suggested that I should make an appointment to get the cyst removed, I advised him that was why I was here, he appeared a bit flustered but managed to rustle up some grumpy nurse to assist. The minor op which I thought would take about 5 minutes went on for what seemed like forever with the doctor tugging & pulling at my numb back while complaining about the blunt scissors & giving me a blow by blow description of what was going on. I polity suggested the he cease & desist with the graphics as I wasn't far from throwing up all over the bed. Eventually the agony (metal not physical) stopped, by which time I was a ball of sweat, I sat up just in time for the doctor to walk past & hold up a plastic container with a huge chunk on my back in it and pronounce, " she was a beauty alright" he then walked straight out of the room & left me on my own. Well within seconds of him leaving, the room was spinning, my mouth was watering & I came VERY close to throwing up & passing out on the floor all at once. Fortunately I had the mental where for all to lay back down on the bed. Eventually the nurse came back in, I regained some of my composure (some was lost forever In retrospect I probably should have taken the rest of the day off, but I didn't. I started covering the test grill cover & it wasn't going all that well, when I got to the corners things where really starting to fall apart and I didn't have my normal composure to step back & think it through, instead I thought I would remove the masking tape from the speaker so I could fit the cover when it was finished, well that's where things really went to HELL. When I was removing the tape it pulled off some of the water based clear coat I had put on the speakers, it did this in a location that wont be seen but you may as well have stabbed me with a knife (I had two onlookers by this time which really didn't help either) to say I was devastated is an understatement, I returned to the grill cover and things just kept getting worse. It wasn't long before I was hacking at the grill cover with a pair of scissors like someone out of a Alfred Hitchcock movie, I suspect the onlookers where thinking of calling the men with the padded suit to give me a fitting. Anyway I did some repairs that will just have to do, but the virgin has been forever defiled. Today I had another go at the grill cover & as you will see in the photo it doesn't look too bad, I think I have finally worked out a system to get the covers the way I want them which means I will have to pull this one apart one more time & hopefully make the next three only once, given my track record that's probably wishful thinking. For reference the other photo shows the blue masking tape that I removed. I have failed in my mission to get the speakers completely finished before returning to work, there it still tomorrow but I am putting up the white flag for the moment. I have taken the speakers back to my bedroom where they belong so I can recharge my batteries with some beautiful music, the covers will just have to wait. Hopefully next weekend I will be install speakers I my sons car. |
#446 |
Sorry to hear about all the troubles today. I'm pretty squeemish to, so I might have gone over the edge and puked right there. My brother had a vasectomy last year and the doctor asked if he cared to have a look while it was happening! Has ANYONE ever said, "sure, thanks doc!"?
Speakers are really coming together nicely. The home stretch with all of the fiddly bits is the toughest part to push through. I am too lazy to look back through the thread, so how are crossing over/driving these? Active? Greg |
#447 |
You've come too far to rush now... deep breathe and wait for next weekend. We can all wait another week.
#448 |
#449 |
#450 |
Thank you all for the support I appreciate it greatly.
The crossover is a modified Linkwitz ASP, so yes it's active, that was a hell of a learning curve. |
| S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range | gainphile | Multi-Way | 27 | 23rd January 2013 09:51 PM |
| New open source loudspeaker design program project started | Karoliina | Multi-Way | 33 | 10th December 2009 10:18 AM |
| I've started my first project... | Bigun | Full Range | 38 | 8th February 2009 01:15 AM |
| A roast requested on my TQWT design | Christof | Multi-Way | 9 | 29th March 2004 05:57 PM |
