#431 |
Took all day to get the capacitor holders finished and I had help!
The gold bayonet plugs are 5mm & come from the model car hobby fraternity, the socket will be glued into the plexiglass holder & the tweeter + will be plugged in, in series with the speaker terminal. The board the capacitor holder is sitting on is my test spray piece, I sprayed a coat of Mirotone Satin water based lacquer over the automotive acrylic colour & it appears to be fine, it really helps with the metallic finish shine when in the sun, I'll have to get a couple of well placed halogen spotlights for effect ![]() I beat you can't guess what the little hexagon pieces of wood are for. |
#432 |
Great work as usual Mr D . Your cap brakets look better than mine ,I think I'll get you to do my new ones buddy
.Are the hexagon wood pieces made to cover nut or bolt heads .David & family all the best for the new year mate Cheers mal |
#433 |
And I thought I was a perfectionist... your work makes mine look as rough as guts
#434 |
Thanks for the encouragement, it helps when the going get toughs and when I'm disappearing up my a#se
![]() You'll notice Ive only showed you one of the capacitor holders ![]() The hexagonal pieces of wood are to cover up the holes at the top of each leg. Have a great New Year |
#435 |
Hi david in the Netherland we have a saying when there are many compliments "put a feather in some ones behind".
After such precise craftmanship I have to put a, in your behind to. ![]() Happy new year to all Diyaudio members to.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 31st December 2012 at 01:08 PM. |
#436 |
I haven't looked in on this build for a while. Great work. Really stunning.
My "Art" website http://home.comcast.net/~djnagle/site/ |
#437 |
Thanks guy's, in Australia it's " Blow warm air up you ar#e" I think I like the feather better
![]() It's been a very hard day at the office! After I put the primer (blue paint) on, and before I put the finish coat on the boxes I made sure they would fit together, guess what, they don't want to go together even though there is no extra paint where they join. I spent hours getting the bass driver box into one of the outer boxes. I assume it's weather related, it's a lot hotter & more humid than when I did them originally. In the end I put the bass box in front of the air conditioner for an hour or so & that did the trick, of course there is the possibility the box may expand & break the outer box .Anyway tomorrows another day. |
#438 |
#439 |
Number 2 is almost done, I still have to make the grill covers & small covers for where the wires are terminated on the mid & tweeter.
If you look closely you'll see a couple of extra holes that I mistakenly drilled long ago, still haven't decided what to do about them. |
#440 |
Cool banana's
| S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range | gainphile | Multi-Way | 27 | 23rd January 2013 09:51 PM |
| New open source loudspeaker design program project started | Karoliina | Multi-Way | 33 | 10th December 2009 10:18 AM |
| I've started my first project... | Bigun | Full Range | 38 | 8th February 2009 01:15 AM |
| A roast requested on my TQWT design | Christof | Multi-Way | 9 | 29th March 2004 05:57 PM |
