#421 |
With what I had at hand, works a treat.
#422 |
I managed to spray a couple of coats of finish on the external base boxes, the colour is darker that I expected so I am holding off putting more coats on until I'm ready to put them together, by them I'll have decided whether to change the colour or stick with what I’ve got. The looks black until you put them beside the inner boxes which are black, then you can see the slight gold in them. The metallic gold sparkles beautifully in the sun, but they won't be spending anytime in the sun
.I planed all of the legs ready for routing & managed to get two done, the second leg took 65min just to do the routing, without stopping. The first one took longer! Only six & a half hours of routing to go Then they will need lots of careful sanding, 1% inspiration, 99% perspiration.PS: If you look at the bottom 2 holes of the box you will see where a wasp made a home for some eggs while they where drying, needless to say they wont be hatching. Last edited by DQ828; 1st December 2012 at 08:43 AM. |
#423 |
Nice legs
![]() ![]() Cheers |
#424 |
After spending all day shopping & cleaning I managed to get another leg done, I'm whittling them away slowly
#425 |
#426 |
#427 |
Still plugging away, the legs are sanded & have a coat of oil finish on them, I intend on putting a couple of coats on before I fit them to the boxes.
I have changed the finish from a brush on lacquer, to the wipe on oil finish because I wasn't happy with the lacquer finish I had already put on the MEN. It's a finish I've used many times before but this time it wasn't doing it for me. This of course means I have to remove the lacquer I have already applied, yeah I know "my own worst enemy". I think I have already mentioned I wasn't completely happy with (is this man ever happy) the colour of the boxes, too dark & not enough sparkle, well now I have a small tin full of Gold Pearl to play with, this could really stuff things up I've ordered some 1/4" brass coach bolts to screw into the bottom of the legs to act as adjustable feet. |
#428 |
Well a little bit of Gold Pearl goes a LONG way. Initially I put 10ml in with 150ml of colour & it was way too much, I ended up using 5ml & I'll have to say the colour is just about perfect. Originally I wasn't going to put clear coat over the colour but it marks really easily, I think it has something to do with the texture as well. Does anyone know if you can put water based acrylic over automotive acrylic 1K lacquer?
If I had my time over I would do several things differently, wouldn't we all!. First I would have stayed with the original plan & used a metal bracket to support the bodies as was the original plan. I went away from the metal bracket as I would not have been able to make them myself at a higher enough quality. In retrospect I should have forked out the money & paid a professional to make them for me, as going to the carbon fibre alternative (which works just fine) has added an enormous amount of work. I would not do the box within a box as it has also added an enormous amount of work, it was done to keep the box size to an absolute minimum size. And last I would probably have made the base for the bodies out of stone (marble, granite?) and isolated the body from the base using some sort of dampener and not actually fixed the bodies to the box, just relied on the weight of the stone. If I hadn't done everything twice it would have speeded thing up as well, some things I've done several times I am using 1/4" brass coach bolts as adjustable legs for base of each timber leg. I'll have to say I'm just about over it, but there is light appearing at the end of the tunnel now. I am using a protection cap for the tweeters & have stolen 56's idea re the perspex brackets to hold them, I should have known anything 56 did would take forever to do, I don't think they will be quite the quality of 56's either. |
#429 |
Impressive work!
I wish I had the patience to get my speakers looking half as good as yours. My OB's look like something you would find in a dumpster, but they sing
#430 |
| S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range | gainphile | Multi-Way | 27 | 23rd January 2013 09:51 PM |
| New open source loudspeaker design program project started | Karoliina | Multi-Way | 33 | 10th December 2009 10:18 AM |
| I've started my first project... | Bigun | Full Range | 38 | 8th February 2009 01:15 AM |
| A roast requested on my TQWT design | Christof | Multi-Way | 9 | 29th March 2004 05:57 PM |
