OB Project Design Started, Help Requested.
Old 11th November 2012, 08:11 AM   #411
DQ828 is offline DQ828  Australia
DQ828's Avatar
Originally Posted by 56oval View Post
What brand is the Bumper texture and do you have a link to the product . Acrylic lacquer is a single step product use with the required thinners and spray not water based .
Search on the NETT for its TDS.
As for cables I'm going with MOGAMIŽ - Bulk Cables
Cheers
The Bumper Texture is, or was, made by K&H, which have been taken over by 3M, it is very hard to find any data on the product & it doesn't show up in the 3M K&H Product list, I had some info on in but now I cannot find it. The info I had indicated you couldn't use 2K finishes over it hence the Acrylic Lacquer.
I'm a bit lost by what you mean with "Search on the NETT for its TDS."
Old 11th November 2012, 09:02 AM   #412
56oval is offline 56oval  Australia
Sorry David , Technical Data sheet .
I would say just use a acrylic paint with the correct thinners .
Is it
SMASH SUPPLIES :: Paint :: K&H Bumper Coat 1lt
http://solutions.3m.com.au/3MContent...bute=ImageFile
Cheers
Old 11th November 2012, 11:34 PM   #413
DQ828's Avatar
At about 11:45pm while I was trying to get to sleep the words "Technical Data sheet" popped into my head
This is the product, your previous advice would still stand with this product as well.
SMASH SUPPLIES :: Paint :: K&H Bumper Texture Coat Black 1lt
Old 12th November 2012, 04:17 AM   #414
DQ828's Avatar
I have called #M & they cannot find it in their system, it may have been discontinued I better go out & buy another can, then of course if it doesn't do the job I'm stuck with 2 cans of bumper texture coat
Old 24th November 2012, 09:15 AM   #415
DQ828's Avatar
I don't think it's ever going to end!
I had just finished spraying the texture coat on the base boxes when I found a blob of something on one of the sides that was still wet, and of course it wasn't on the bottom. Initially I managed to get get most of it off, but when I tried to get that last little bit off, it turned into the disaster you see in the photo. There's always tomorrow I guess, I was hoping to spray the topcoat tomorrow.
Old 24th November 2012, 11:21 PM   #416
Its a prick when something like that happens .What was it a peice of unmixed product in the paint .
What you really need to do is strain it through a filter into another container then pour it back into the can to remove contaminants .
I roll masking tape back on itself to make it double sided and press lightly on the foreign particle to remove it . But you need to do this while the paints wet .
Looking really nice David .
Cheers
Mal
Old 25th November 2012, 05:01 AM   #417
DQ828's Avatar
Cheers
Mal
I'm not sure what it was, it was too large to have come out of the gun & it wasn't wriggling so it wasn't a bug, it was just a piece of bad luck
I did the respray today & am happy to report all went well.
Originally I was going to spray the colour coat on all surfaces but have decided to only coat the outside of the large boxes as that is all you will see once the grill covers go on.
Getting a good coat inside the boxes is a real challenge.
Old 25th November 2012, 07:12 AM   #418
DQ828's Avatar
Default Denibbing
While I was at the auto shop buying the paint I saw this De-nibbing tool & sanding pads 3M? Perfect-It? Denibbing System - YouTube, great idea but a bit expensive so I made my own which I will use in my Dremel.
I used an old dremel bit, Araldited on a Western Red Cedar disc, which was cut using a sharpened piece of SS curtain rod, I then sanded the disc so it was perfectly round, coated the end of the in Araldite, stuck on a piece of self adhesive hook & loop, cut a disc of P1500 grit hook & loop paper & $350.00 was saved, the $350.00 doesn't include the pad larger disc sander in the clip.
Old 25th November 2012, 07:38 AM   #419
Cool , how about the foam between the sand paper and the arb .Have you used it yet ,make sure it doesn't run off across the job with something hard like the red cedar as a cushion.
Theres some great little tools out there .
CHeers
Old 26th November 2012, 06:53 AM   #420
DQ828's Avatar
CHeers
Hmm, maybe there is a design change in the offing, I probably have a bit of foam somewhere.
The Velcro does add a little bit of give, I have tested it but not on the actual finish, I was thinking of making an even smaller one, there is a couple of minor dirt flecks that I could sand out before the finish coats.
OB Project Design Started, Help Requested.Hide this!Advertise here!
S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range gainphile Multi-Way 28 27th May 2016 08:13 AM
New open source loudspeaker design program project started Karoliina Multi-Way 33 10th December 2009 10:18 AM
I've started my first project... Bigun Full Range 38 8th February 2009 01:15 AM
A roast requested on my TQWT design Christof Multi-Way 9 29th March 2004 05:57 PM
