OB Project Design Started, Help Requested.
Old 6th October 2012, 04:13 PM   #401
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Originally Posted by DQ828 View Post
I'm thinking maybe the leg is a little too fat.
Nice craftsmanship David that leg respect.
For the looks a simple square one looks better I think, that is my taste clean simple. Spikes in the foot of the leg will make a cool impression.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 7th October 2012, 10:22 AM   #402
DQ828 is offline DQ828  Australia
DQ828's Avatar
I'm a curvy sort of guy
Old 7th October 2012, 10:34 AM   #403
Helmuth's Avatar
shape example for each leg.
Old 7th October 2012, 09:51 PM   #404
DQ828's Avatar
DEFINITELY
Old 7th October 2012, 09:54 PM   #405
DQ828's Avatar
Originally Posted by studiotech View Post
No way. Any thinner and it would look insignificant. You don't want it to look like a skinny dining table chair leg do ya?
I only mean a little bit, but I take you point. There is a slight flat spot near the top you can't see, I'll make one more test piece & make my mind up from there.
Old 11th November 2012, 06:18 AM   #406
DQ828's Avatar
Progress has been slow, it's not from a lack of trying though.
I have now made three prototype legs & modified one of them to finally arrive at a shape I am happy with. Now all I have to do is make eight more, why eight if I already have one I'm happy with, well it turns out I'm not happy with the colour of the Tasmanian Blackwood I bought from the local supplier. It is too blond and will not give the appearance I am looking for. When I bought the wood I compromised, because the next supplier about 160klm away. Once I had seen the finished (Blond, see photo) leg I knew it wasn't right and would only annoy me for the rest of my life if I didn't change the timber. Each leg takes at least half a day to make so I still have a long road ahead.
I have sprayed the base boxes with 2k primer, the next step for them is to spray them with K&H Bumper Texture coat & then with automotive acrylic enamel. The color is from an Alfa and is called Bronze Metallic.
I have spent the last day & a half joining the Mid driver section to the tweeter driver section, it turns out the CNC router didn't cut the recesses as I expected, it was surprisingly difficult to get everything to line up properly.
Hopefully I will get the speakers finished over the Christmas break.
I still haven't decided what to do for feet, the speakers have to be about 35mm off the floor to accommodate the speaker connections which will be under the bass box, spikes are out, I'm not a fan.
Old 11th November 2012, 06:28 AM   #407
56oval is offline 56oval  Australia
Hi D
Looking great as usual , do you need to put a flexy aid in with the acrylic enamel since its going over the top of Bumper texture .
CHeers
Mal
Old 11th November 2012, 06:53 AM   #408
DQ828's Avatar
Default Cable Suggestions Requested
I have been pondering what type of cable to use to connect the drivers to the speaker terminals at the bottom of the Bass box. Because of all the effort I have gone to, I thought it would be nice to use a good quality cable, I don't want to break the bank though.
All suggestions are welcome.
the recess for the cable either side of the mid driver is 3.9mm wide so the cable can't be too large
Old 11th November 2012, 06:59 AM   #409
DQ828's Avatar
Originally Posted by 56oval View Post
Hi D
CHeers
Mal
Mal
I know so little about this stuff I thought acrylic enamel was water based
Given the bass boxes shouldn't flex like a bumper might, maybe I don't need the flexy aid?
The Bumper Texture coat say's I need to use acrylic lacquer over it, which I assume is acrylic enamel.
Old 11th November 2012, 07:12 AM   #410
What brand is the Bumper texture and do you have a link to the product . Acrylic lacquer is a single step product use with the required thinners and spray not water based .
Search on the NETT for its TDS.
As for cables I'm going with MOGAMIŽ - Bulk Cables
Cheers
OB Project Design Started, Help Requested.Hide this!Advertise here!
S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range gainphile Multi-Way 28 27th May 2016 08:13 AM
New open source loudspeaker design program project started Karoliina Multi-Way 33 10th December 2009 10:18 AM
I've started my first project... Bigun Full Range 38 8th February 2009 01:15 AM
A roast requested on my TQWT design Christof Multi-Way 9 29th March 2004 05:57 PM
