OB Project Design Started, Help Requested.
Old 18th June 2012, 10:27 AM   #351
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Then I would advise the discovery Scanspeak series very nice drivers, low mechanical losses good linearity great-brand name and very nice price. Cross it low 1.5kHz because of ctc spacing.
http://www.scan-speak.dk/datasheet/pdf/18w-8434g00.pdf
http://www.scan-speak.dk/datasheet/pdf/r2604-833000.pdf
http://www.scan-speak.dk/datasheet/pdf/d2604-830000.pdf
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 18th June 2012, 07:02 PM   #352
56oval is offline 56oval  Australia
Originally Posted by DQ828 View Post
With the sisters speaker I was thinking maybe something more like the PHL Mid Bass 1330 or 1220 with a dome tweeter.
I did like the price point of your suggested driver.
PHL goodness ,hows it going David .Your amps look great mate .
Cheers
Old 19th June 2012, 07:18 AM   #353
DQ828 is offline DQ828  Australia
DQ828's Avatar
Cheers
Well it's VERY nice to hear from you, I bet your amps are better, are they finished or shouldn't I ask?
Old 19th June 2012, 07:19 AM   #354
DQ828's Avatar
I will check them out.
Old 19th June 2012, 10:41 AM   #355
Hi David
I'm still keeping track of your projects .I doudt my amps are any better than yours its all about the how the whole system works together .
Cheers
Mal
Old 27th July 2012, 09:20 AM   #356
DQ828's Avatar
Progress has been very slow, too many projects, too many interruptions.
I have cut Tasmanian Blackwood to about 5mm thick & laminated it on the front face. Unfortunately when I route the curve on the edges the grain gets raised in the sections that the router bit is running against the grain. There is no way of avoiding going against the grain. I am using a brand new bit but still the grain gets raised & dug out.
I will try modifying an old bit tomorrow to see if I can improve things. As yet I have not cut the full curve. I was hoping to avoid using too much sandpaper as it will take the crispness off the curve, but I don't think I will have much chose.
The plywood edges will be black at the end of the day.
What I REALLY hate is having my fingers so close to the router bit when I'm curving the head section, scary stuff
Old 27th July 2012, 09:24 AM   #357
DQ828's Avatar
Default PAINT SUGGESTIONS
I'm going to paint the woofer box & plywood edges black, charcoal or some similar colour. I would even like a paint that had a bit of a sparkle to it, only a little bit though.
Do any of you aussie's know of such a paint?
Old 27th July 2012, 10:16 AM   #358
How about the charcoal grey hammer tone I used on my amp case's ,looks nice inside .
Or an automotive metalic grey . being inside you mighten need to clear it to protect the metalic .But cleaning it could be a problem .
Do you want the cab's to look shiny or a satin or matt finish .
Cheers
Old 27th July 2012, 10:41 AM   #359
DQ828's Avatar
Cheers
Hi 56
I was going for a Satin to almost matt finish, I think the automotive is probably the go, if it can be done in a Satin, I seem to remember you where toying with some pretty outlandish colurs for something at one stage
Any suggestions?
I used the hammer tone one one of my little projects but it's not what I'm looking for for the speakers.
DQ
Old 27th July 2012, 11:14 AM   #360
Heres a couple of cabs I painted for a SNA member .He wanted a satin finished that could be cleaned .So i mixed 10% flatten base into the paint & the last couple of coats I thined it down a little bit more .
Don't forget painting satins and matts its very hard getting dust out of the paint without
painting the surface again .
Cheers
OB Project Design Started, Help Requested.Hide this!Advertise here!
S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range gainphile Multi-Way 28 27th May 2016 08:13 AM
New open source loudspeaker design program project started Karoliina Multi-Way 33 10th December 2009 10:18 AM
I've started my first project... Bigun Full Range 38 8th February 2009 01:15 AM
A roast requested on my TQWT design Christof Multi-Way 9 29th March 2004 05:57 PM
