#301 |
Hi David,
I just wrote a small article on measurements of dipole loudspeakers. Hopefully we can compare notes. Note that I never measure at listening distance. Gainphile: Measuring Open Baffle loudspeakers
http://gainphile.blogspot.com |
#302 | |
Like I did here. A backloaded horn low and horn midhigh.Project presentation Horn Almighty
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 10th January 2011 at 03:02 PM. |
#303 |
I also struggle with the concept of measuring only in free space away from boundaries etc. Isn't it best to do both, when possible?
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#304 |
One can't correct deviations in time domain with amplitude adjustments.
Otherwise DSPs would have solved all of our 'problems' by now.
#305 |
Just finished reading Gainphile's "Measuring Open Baffle Loudspeakers" Interesting. Can't wait to read Gainphile's "Advanced" topics, especially "why passive dipoles won't work". Need to know how my well received passive OB designs manage to please so many? Hmmmm.....? Northern CA DIY, LSAF, RMAF......
#306 | |
#307 |
I'd definitely like to read that too. It's very much news to me as my ears and measurements told me (my) passive open baffles can work, and if this is the sound of "not working" then sign me up for more!! Sure, there are trade-offs but "won't work" seems a bit strongly-worded. It also implies the author hasn't tried - yet??
#308 |
It is not my intention to offend anyone. I have reworded it to "Difficulties with passive dipole loudspeakers."
#309 |
I'm all for measuring outside for crossover purposes & to see how the crossover is working, but for me the final adjustments are made in the room.
I had the tweeter EQ'd within an inch of its life, showing a fairly impressive looking line, in the end I turned the tweeter specific EQ off & left the global high shelving on and liked the result better, even though the measurement didn't look so good. My passive P17 clones sound pretty bloody good to me and may others, no audio nuts though. (they didn't measure well). I think the approach of keeping it simple, like the P17 crossover, can have benefits David |
#310 |
Since I reported "I think I'm happy for the moment" I was listening to some classical guitar & thought the highs where a bit lacking, so guess what, I had a fiddle, imagine that.
I changed the high shelf configuration a little & "I think I'm happy for the moment" ![]() Or maybe not, we will see, they are sounding great though. I was convinced to go active by the boys on the forum, "it'll be much easier they said" & they where right in one respect, it SO much easier to change the crossover & EQ 10mins & your done, with no dirty hands, I'm glad I did. Its also lead to another project, six channel amp. ![]() David I should have said 2 extra projects, the active crossover of course. Last edited by DQ828; 11th January 2011 at 06:36 AM. |
| S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range | gainphile | Multi-Way | 27 | 23rd January 2013 09:51 PM |
| New open source loudspeaker design program project started | Karoliina | Multi-Way | 33 | 10th December 2009 10:18 AM |
| I've started my first project... | Bigun | Full Range | 38 | 8th February 2009 01:15 AM |
| A roast requested on my TQWT design | Christof | Multi-Way | 9 | 29th March 2004 05:57 PM |
