Old 8th October 2010, 03:37 AM   #1
Speakerholic
Cal Weldon's Avatar
Default Interesting mid/high module
From a Community 4X12 3 way. I would like to concentrate on the mid as the 4X piezo, while interesting is not really my cup of tea even though it seems to be a really nice implementation.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 8th October 2010, 03:42 AM   #2
Speakerholic
Cal Weldon's Avatar
Convex metal dome behind the metal mesh plus extended diaphragm (all one piece with glued coil), no phase plug and lightly damped back chamber (cavity in the pole piece)
Old 8th October 2010, 03:49 AM   #3
Speakerholic
Cal Weldon's Avatar
Assembled unit from the front ready to mount to the module. I find this rather interesting especially the diaphragm, Not sure I've seen that before. Anyone else?
Old 8th October 2010, 03:53 AM   #4
CLS is offline CLS  Taiwan
I've only seen it on the datasheet (there's a cutaway view showing that), and found it very interesting too.
How does it sound? Is it still available?
Edit: The 'phase plug' still exist, just not cover the dome. It block the 'suround' - or should be seen as the outer area of the whole diaphragm.
Old 8th October 2010, 04:23 AM   #5
Speakerholic
Cal Weldon's Avatar
Hi, I just had a look at the cut away diagram and now it makes more sense, thanks. As far as the sound goes, I'll have to leave that for another day and will report back. I'm busy using the other parts of the speaker.
Old 8th October 2010, 09:40 PM   #6
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Originally Posted by CLS View Post
..Is it still available?..
check nothern sound and light
flesh flash flush
Old 9th October 2010, 11:58 PM   #7
Speakerholic
Cal Weldon's Avatar
Originally Posted by Cal Weldon View Post
Convex metal dome
Turns out it's Mylar which if I remember correctly is DuPont's trade name for aluminum oxide coated polyester.
Old 10th October 2010, 12:19 AM   #8
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
From a CSXs2 cabinet right? Used the 57s2's for many years. Actually a very good sounding fuzzy box. Mostly eminence drivers inside so replacements were inexpensive. The automotive light bulbs were a trip. You knew you were out of gas when the ports lit up! The M200 diaphrams should still be stocked. I think they crossed the piezo's really high so they just added some sparkle.
Old 10th October 2010, 01:06 AM   #9
norman bates's Avatar
m200 = awesome sounding midrange compression driver (m200a is a bit better). The low 4:1 compression ratio makes it smooth and easy to listen to compared to the typical 10:1 ratios. The m200 has a peak then shuts off. You can't eq the highs in.
There is a newer version, the m200a or also the same compression driver used in the avante-garde trio, but they use a different impedance for volume level matching.
Best to run m200 24db LR active crossed at 600hz and 4khz.
The stero lab 400hz spherical tractrix from Germany should be best assuming you can live with the directivity of a tractrix. Myself, I like a wider dispersion cd horn, but I bet the round horn has less reflections than my ev h90 (great horn), or anything else out there.
look on audioasylum.com for an author named djk. Unlike others, he has extensive experience with them.
Norman
Old 10th October 2010, 01:47 AM   #10
Speakerholic
Cal Weldon's Avatar
Yes the CSX70-S2
Aren't they? They have enough goodies in that there XO to make a half a dozen speakers by my reckoning.
I think they crossed the piezos really high so they just added some sparkle.
They quote a 4K XO and that would make sense with the M200 but I would have no idea. That XO reminds me of a Calcutta traffic jam.
They actually say 1.84:1 so that seem even better? Certainly an interesting take on the word "compression". If the attachment shows up then you'll see why I think this is an interesting set up from a set of speakers that I basically "stole" from my local public house. It's nice when the owner drinks too.
No plans for it quite yet. Just robbed the woofers for a new "itch" I am hoping to scatch. The mids do sound good though, perhaps something in the next couple'o'years. There are many projects on the board whereby the product is getting a more than wee dusty. My urge to compile projects seems greater than my capacity these days.
The piezos, what can I say... I am considering using them instead of speaker spikes.
Oops, did I say that? Sorry Mr. Motorola
Biamp with high-mid pasive filter. ubaid88 Chip Amps 1 19th April 2009 04:31 PM
FE 206 ESR mid high ? Lagroute Full Range 9 11th January 2007 02:22 AM
Goto mid-high drivers and horns giolight Swap Meet 2 17th May 2004 08:52 PM
Bass/mid/high, are you sure? Raka Multi-Way 4 28th September 2003 04:22 PM
Page generated in 0.10718 seconds (81.52% PHP - 18.48% MySQL) with 11 queries
