Phase plug design for high-directivity horn Phase plug design for high-directivity horn - diyAudio
Old 5th October 2010, 11:54 PM   #1
Spatz is offline Spatz  Germany
Default Phase plug design for high-directivity horn
Hi everyone,
I'm looking for hints and tips on designing a horn/plug combination for a cone driver (5 inch). It should have high bandwidth (no need for a tweeter or a separate midrange, 500Hz - 15kHz would be perfect) and high directivity (angles less than 50).
It is possible, the Funktion One Resolution 1 shows that, but I can't find any information on designing a horn/plug combo as they did. I only know that the plug is connected to the pole plate and the compression chamber is as small as possible.
Does anyone have more information on designing plugs like these?
Bye,
Bastian
Old 4th October 2014, 06:10 PM   #2
stewin is offline stewin  Kenya
try this method
Old 4th October 2014, 06:34 PM   #3
6" horn - Speakerplans.com Forums - Page 1
Phase plug design for high-directivity hornHide this!Advertise here!
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
10 hz horn design phase problems oublie Subwoofers 18 28th February 2010 06:37 PM
Constant Directivity Horn EQ Horizons Multi-Way 4 19th December 2008 11:41 AM
Constant directivity horn - or waveguide? hasselbaink Multi-Way 6 1st April 2008 01:24 PM
Phase plug for cone driver in mid-bass horn design? mefistofelez Multi-Way 2 18th October 2003 07:59 PM
Copyright ©1999-2017 diyAudio
