Take a look at this.
I want to understand the "Dual force canceling subwoofers" they speak of... What is the principle? Is it some severe thing or something as simple as reversing the phase of one of the two subwoofer signals?
#2 |
The drivers are acoustically in phase (as they move out, they pressurise the room), but mechanically, they move in opposite directions.
I designed my last subwoofer and speakers with a similar thing in mind, as (being 16) I live with my parents, who don't enjoy bass comming through the ceiling. Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#3 |
Imagine a subwoofer with a huge super heavy 18" cone on the front.
Sir Isaac Newton told us that for every action there is an equal and opposite reaction. Therefore, as the cone moves in and out, the cabinet must rock back and forth slightly to compensate. This generates slight acoustic vibration into the air and probably into the floor. Now if you mounted an identical cone on the back, with the same polarity, the mechanical motions cancel. When both cones move in or out, there is no net momentum and the cabinet won't rock (at least not due to the cone motion). |
#4 |
If you mechanically link the two opposite drivers you can decouple the driver mountings from the cabinet without any real effect. This is the ideal way of doing it, reducing direct cabinet vibration. rgds, sreten. |
#5 |
Which is exactly what Thomas Barefoot did here.
#6 |
frugal-phile(tm)
Also call push-push. Mechanical linkage is important... some commercial designs that use the enclosure as the linkage miss the point.
KEF can possibly be credited with the 1st commercial implementations. This concept shows an extreme implentation including a specially executed woofer. toobz woofer ![]() Whenever possible i use this technique as it can remove a very significant amount of energy from the box, dramatically reducing boxiness and the likelihood of resonance excitation. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
frugal-phile(tm)
From the info, those are powered speakers, not active... do they actually use a passive XO on the woofers?
From the attached image, these guys do a good job of the push-push. dave
#8 |
No they are fully active. These little ones use 50w for the tweeter, 100w for midwoofer and 200w for the sub.
#9 |
frugal-phile(tm)
Cool, i only noted the 50W in the spec. How expensive are those?
dave
#10 |
US$ 2747.50 each at Vintage King. There could be a waiting list, studios buy them quicker than Thomas can make them!
| Beyond the Force? | moray james | Class D | 10 | 19th January 2006 09:00 PM |
| Sound Canceling - Project | keyboarder89 | Everything Else | 12 | 1st February 2005 12:07 AM |
| Help on Brute force | Ryssen | Tubes / Valves | 5 | 2nd May 2004 10:07 AM |
| dual speaker | JBL | Multi-Way | 3 | 2nd December 2001 08:53 PM |
| Page generated in 0.12026 seconds (67.80% PHP - 32.20% MySQL) with 11 queries |
